XS Power
No you cannot put it on the d3100. The ibar you can put on the 3100 is the 556 and 554. Are you trying to stuff a 3100 in your engine?
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Yeah since you cant use the ibar are the OEM wires long enough to reach the top of the battery? If so just get some ring terminals on there and bolt it up. If not then I would suggest to take the stock starter, ground, alt, etc wires and upgrade them with your own wire and ring terminals. Its not that hard to do as long as your wires aren't buried in the engine.
Thanks alot another question what is the biggest batt i can fit in the stock battery tray its supposed to be the d3400 but i dont know for shure im not putting the second bettery on the washer fluid container place im instead going to put a small toolbox the ones that go below your truck bed and putting 2 d7500 in there but want to know whats the biggest i can put in my 05 f150 battery tray
Measure it? All the dimensions are on the xs website
x2 get dimensions and check it out.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
