Normal for an impact gun to do this?
meh. I don't think the compressor is the cause of the symptoms. I think its in that gun.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
20 gallon compressor is a little light for that tool as well.
If that's seriously not enough I'm returning it. Don't have the budget or space for anything bigger
tank should be fine for what your using it as and is definatly not what is causing the problem for the gun.
look for receipt or waranty
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
don't have enough scfm a 1/2 in impact needs about 5.5 your is 4 thats the reason,scfm is the amount of air flow the higher it is the faster the air comes out.it happen to me to had a nice air compressor that was 6 scfm then motor crack on it bought another one that is 4 scfm it does the same thing like your doing.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Ahhhh lame.
I guess air tools just aren't for me then. Can't find a 6cfm compressor that's within budget and won't necessitate either wiring to a 20 amp plug or 240v lol
Thanks for the help guys
you mean psi??
no, you see in the video scfm on the compressor you want to match that a 1/2 in impact needs about 5.5 scfm, whats the model of the impact
2 sundown sd-2 d4
flex tech
box design by Joe X
the impact is rated in cfm 4 which is like 4.8 scfm thats just a guess but it something like that.my auto parts guys tells me an 1/2 impact needs at least 5scfm
2 sundown sd-2 d4
flex tech
box design by Joe X
Waaaaiiiiiitttt hold up. Just did some reading.
CFM is what the compressor's pump can supply. Like an alt.
The rest of the tank just holds the air, you can even grossly exceed the compressor's output. In bursts though. Like batteries.
In the video, the compressor was charged to 150 psi. Never once did the pressure dip low enough to cause the pump to kick back on. So whether my pump was 4cfm, 1cfm, or 38 cfm, it was off the whole time and I didn't draw enough air to necessitate a recharge.
So how is it that I need a bigger pump? Is the issue with my compressor or the impact gun? Or something else?
  • Who's Online   1 Member, 0 Anonymous, 1307 Guests (See full list)
