soundstream15 Posted August 28, 2013 Author Report Posted August 28, 2013 If this helps, when I play decaf I drop to low 13s, if I play for example money man non decaf it drops to low 12s...kinda wired. And I played the same song in decaf and dropped to 13s. Stange! @snowdrifter if you can please PM me
DubNDodge Posted August 28, 2013 Report Posted August 28, 2013 Here's a question, what size was your stock alt? If it was 120A and you got one that is 170A now you will see improvement, but not jaw dropping results. Well at least in my opinion. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Kyblack76 Posted August 28, 2013 Report Posted August 28, 2013 Look on your alt. Any sort of black, powdery residue on it? And measure your voltage drop at the amp with a DMM Good call on looking for dead belt on, and around the place.. ALso, love my fluke, for the MIN MAX setting..... (i just got done doing this very thing, like 20 seconds ago) I plug my leads in, (i just push them through the power/ground lead of amp) and.. just drive around banging nuts...... Then,.. i roll up to the pad, and just scan through, and see the MIN, the MAX and the AVERAGE... fucking LOVE that feature.... It will tell you things, even a ANALOG volt meter cant.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted August 28, 2013 Report Posted August 28, 2013 If this helps, when I play decaf I drop to low 13s, if I play for example money man non decaf it drops to low 12s...kinda wired. And I played the same song in decaf and dropped to 13s. Stange! @snowdrifter if you can please PM me Says you can't receive new messages You'll want to look at the alt casing. It should be pretty obvious if it's slipping. Slip = covered in a sticky, rubbery dust. No slip = clean (or dirty ) alt Edit: Just FYI my alt used to slip like crazy. Wouldn't make a sound and the belt *looked* good. But the alt was COVERED in belt powder and performance suffered ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
soundstream15 Posted August 28, 2013 Author Report Posted August 28, 2013 Stock 105amp And that's weird dude, I'll message you from a old message
twisted1 Posted August 29, 2013 Report Posted August 29, 2013 Could be bad alt, bad grounds. Decaf doesn't draw more current because its boosted and dosnt take as much power to bang 09 mustang gt
soundstream15 Posted August 29, 2013 Author Report Posted August 29, 2013 My grounds are good, the alternator is brand new. It's my belt bc it's a little loose so gotta get a new one..
