rockFord_Expedition Posted September 2, 2013 Author Report Share Posted September 2, 2013 And consensus says, if you've got the money, get Steve's sunflash. It's great for beginners. Using the stuff from home depot or Lowe's is cheaper and convenient, but you'd waste a lot of product just getting used to it and getting the mixing down right.ummm no i dont reccomend that at all, have you used his sunflash because i have its great for getting your first shape but then you need to use reggular resin to strengthen In what application did you find the sun flash lacking strength? Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2013 Report Share Posted September 2, 2013 Sorry dude, it's hot here in AZ. I mixed body filler last weekend and it setup in 4 minutes. Way too much hardener man I use a syringe with CCs marked on the side and I use Slow reacting MEKP in the summer of AZ. Ive got a chart somewhere for how much MEKP per ounce of resin and it also has a column to adjust by outside temp. I can just tell that the account of drops you used was probably at least 3-4 times the amount that sold have been used. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2013 Report Share Posted September 2, 2013 FYI, you just need SOME catalyst and mixed well. It WILL setup since its a chemical reaction. Cut your recipe by 1/3 and see if that does the trick. It may take longer to setup, but it will setup Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
will77530 Posted September 2, 2013 Report Share Posted September 2, 2013 And consensus says, if you've got the money, get Steve's sunflash. It's great for beginners. Using the stuff from home depot or Lowe's is cheaper and convenient, but you'd waste a lot of product just getting used to it and getting the mixing down right.ummm no i dont reccomend that at all, have you used his sunflash because i have its great for getting your first shape but then you need to use reggular resin to strengthen In what application did you find the sun flash lacking strength? when i glassed 4 batteries into the back of a 67 camaro and it chipped away like it was nothing it is a laminate resin not structural, great for getting your shape, defiantely an amazing product but if you need strength i would stick with the regular resin, just my opinion Link to comment Share on other sites More sharing options...
will77530 Posted September 2, 2013 Report Share Posted September 2, 2013 this was just a pic while i was glassing did 4 layers of cloth Link to comment Share on other sites More sharing options...
HatersGonnaHate Posted September 2, 2013 Report Share Posted September 2, 2013 Thanks for the hands-on insight Will My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car. Link to comment Share on other sites More sharing options...
David Posted September 2, 2013 Report Share Posted September 2, 2013 They make a bottle that measures the catalyst its alot easier. The sunflash should work for you no problem, I tested it at meades shop and it was just as strong as anything else in have used, If you lay to much resin without something to soak it up it will chip just like any other resin. Link to comment Share on other sites More sharing options...
liljestrand Posted September 2, 2013 Report Share Posted September 2, 2013 You can buy uv activated hardener and add it to whatever resin you have if you wanna try it, can get enough to make 10 gallons for around 50 bucks iirc. Team B2 2008 scion xb bagged on 18's plastidipped matte black 4 18" b2 xc's pushed by 4 b2 m1s at .5 each 8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros. 157.7 sealed so far. Link to comment Share on other sites More sharing options...
