moegej Posted September 2, 2013 Report Share Posted September 2, 2013 I plan on running 2 sundown x-10's on a bc3500 at 1ohm. with the x-10's in a 3.5 cube box is a single 6" aero enough port area? i would really love to be able to run aero ports in this box. If that isnt enough port area what would be enough area? 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's Link to comment Share on other sites More sharing options...
will77530 Posted September 2, 2013 Report Share Posted September 2, 2013 with out plugging it into a program or doing any calculations it should be close, might be a little on the small size Link to comment Share on other sites More sharing options...
ToNasty Posted September 2, 2013 Report Share Posted September 2, 2013 yes thats fine ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
john253a Posted September 2, 2013 Report Share Posted September 2, 2013 normaly idd say 3.5net is on the small side but with 30mm xmas you should be fine idd be wanting more port Link to comment Share on other sites More sharing options...
arrhythmia jeep Posted September 11, 2013 Report Share Posted September 11, 2013 normaly idd say 3.5net is on the small side but with 30mm xmas you should be fine idd be wanting more port so does that mean more x max = less need for port area ? im thinking about a 6'' areo port for a 15 with 12 mm x max in a 4.5 ft box at 28 hz but the torres calculator says ( port area ) is 5.03 per foot is that not enough for 700 rms 1997 zj jeep Link to comment Share on other sites More sharing options...
kirill007 Posted September 11, 2013 Report Share Posted September 11, 2013 More Xmax= more port area generally. A single 6 inch aeroport is a bit on the small side, 3 4 inch aeroports would be ideal. Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted September 11, 2013 Report Share Posted September 11, 2013 I run a 6 inch precision port for two tens it's pretty much perfect for this and I have an inch of xmax peak to peak so I would say probably not. <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
