CJ18 Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) Beginning next weekend I will be testing ALL DC amps on my AD-1. Each amp will be tested at 1 ohm, 2 ohm, and 4 ohm in all 3 modes. How do you think they will perform? I have 30 XS 14v batteries to use for power. I will do my best to get the tests to come out as close to 14.4v as possible. All ratings can be found here for reference. http://www.dcaudio.us/subsamps.html Copy and paste the following and fill out with your guesses for 1 ohm output. 1.2k Certified- Non Certified- Dynamic- 2k Certified- Non Certified- Dynamic- 3.5k Certified- 3379w @14.34v Non Certified- 3834w @14.1v Dynamic- 4993w @14.44v 5k Certified- 6088w @14.62v Non Certified- 5616w @13.5v Dynamic- 7010w @ 14.42v 7.5k Certified- 7286w @14.16v Non Certified- 7698w @13.69v Dynamic- 10064w @14.41v 9k Certified- Non Certified- Dynamic- 10k Certified- Non Certified- Dynamic- 175.4 Certified- Non Certified- Dynamic- Edited September 19, 2013 by CJ18 Quote Link to comment Share on other sites More sharing options...
CJ18 Posted September 5, 2013 Author Report Share Posted September 5, 2013 ... Quote Link to comment Share on other sites More sharing options...
CJ18 Posted September 5, 2013 Author Report Share Posted September 5, 2013 ...... Quote Link to comment Share on other sites More sharing options...
CJ18 Posted September 5, 2013 Author Report Share Posted September 5, 2013 10k First please! !!!! !! ! ! !!!!! awesome... 3.5k will be first, followed by the 7.5k. Quote Link to comment Share on other sites More sharing options...
CJ18 Posted September 5, 2013 Author Report Share Posted September 5, 2013 Yeah you kids beat me too it. Want to save space for video Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) 1.2k Certified- 1243 Non Certified- 1406 Dynamic- 1872 2k Certified- 2101 Non Certified- 2475 Dynamic- 2689 3.5k Certified- 3522 Non Certified- 3613 Dynamic- 3980 5k Certified- 5308 Non Certified- 5524 Dynamic- 5891 7.5k Certified- 7932 Non Certified- 8107 Dynamic- 8308 9k Certified- 9693 Non Certified- 9954 Dynamic- 10365 10k Certified- 10319 Non Certified- 10472 Dynamic- 10853 175.4 Certified- 236 Non Certified- 261 Dynamic- 299 Can't wait for the 9k Edited September 16, 2013 by SnowDrifter Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
CJ18 Posted September 5, 2013 Author Report Share Posted September 5, 2013 Might as well put my guess down too. 1.2k Certified- 1300 Non Certified- 1620 Dynamic- 1975 2k Certified- 2200 Non Certified- 2450 Dynamic- 2800 3.5k Certified- 3675 Non Certified- 3900 Dynamic- 4300 5k Certified- 5250 Non Certified- 5500 Dynamic- 6000 7.5k Certified- 8500 Non Certified- 8800 Dynamic- 9350 9k Certified- 9350 Non Certified- 9875 Dynamic- 10300 10k Certified- 10500 Non Certified- 11000 Dynamic- 12000 175.4 Certified- 283 Non Certified- 299 Dynamic- 330 Quote Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted September 5, 2013 Report Share Posted September 5, 2013 in for results... thats a extensive test list for sure! Quote My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
Dan2427 Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) What are you using for power?? Edit: power meaning like Steve does with his test? Or using the electrical out of your truck? Cuz youe truck charges at 16 volt right? Just curious on how you're doing it! Edit 2: sorry if I'm wrong haven't looked at the f150 build in awhile.. But it's gonna be rebuilt anyway! Edited September 5, 2013 by Dan2427 Quote 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port! Link to comment Share on other sites More sharing options...
Tarball Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) 1.2k Certified- 1305 Non Certified- 1420 Dynamic- 1880 2k Certified- 2195 Non Certified- 2395 Dynamic- 2750 3.5k Certified- 3590 Non Certified- 3712 Dynamic- 3995 5k Certified- 5308 Non Certified- 5509 Dynamic- 5995 7.5k Certified- 7650 Non Certified- 7950 Dynamic- 8400 9k Certified- 9501 Non Certified- 9800 Dynamic- 10500 10k Certified- 10500 Non Certified- 11000 Dynamic- 12000 175.4 Certified- NA Non Certified- NA Dynamic- NA Edited September 5, 2013 by Tarball Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
