Watch the bass Posted September 14, 2013 Report Share Posted September 14, 2013 1.). Clamping is not a reliable way to measure amplifier output. 2.). You're looking at one frequency, try a sweep. 3.). At resonance, the impedance of your sub rises greatly so it would naturally reduce amplifier output. Doesn't mean your sub outputs less, as you've stated. 4.). Check out Tiny D's vids on clamping. 5.). Hard to tell on mobile. If you have multiple wires from your sub terminals, make sure all wires from the same polarity are through the clamp meter. ^^^ Edit - nice, I intercepted a double post!!! ^^^Of "Tiny D. vid´s" Or did he mean "Tyni D vid´s" "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 14, 2013 Report Share Posted September 14, 2013 First things first, cheap meters = even higher flawed results, added with non true rms meters even more skewed results. Link to comment Share on other sites More sharing options...
Karkov Posted September 14, 2013 Report Share Posted September 14, 2013 Reasons why I won't *clamp* my amps. pointless because it's not accurate enough for me to be happy with the results. $.02 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
Wicks Posted September 14, 2013 Report Share Posted September 14, 2013 1.). Clamping is not a reliable way to measure amplifier output. 2.). You're looking at one frequency, try a sweep. 3.). At resonance, the impedance of your sub rises greatly so it would naturally reduce amplifier output. Doesn't mean your sub outputs less, as you've stated. 4.). Check out Tiny D's vids on clamping. 5.). Hard to tell on mobile. If you have multiple wires from your sub terminals, make sure all wires from the same polarity are through the clamp meter. ^^^Edit - nice, I intercepted a double post!!! ^^^Of "Tiny D. vid´s" Or did he mean "Tyni D vid´s" "Tony" ...efffing autocorrect. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
Ryan_Kao Posted September 15, 2013 Author Report Share Posted September 15, 2013 Lol im confused... but anyways, soon an alternator will eb upgrade, and also i have a few people somewhat near me with Termlab so soon ill know some numbers! Build in progress: -Pioneer Premiere DEH-P49OIB _Kenwood Excelon KFCX173 6.75" -Kenwood KFC-1094PS 4" -DB Link 4AWG -Soundstream DTR1.900D -Obsidian Audio v2 12" D2 @1ohm -L-Port, 2.5cubes @32hz CHECK ME OUT ON YOUTUBE Link to comment Share on other sites More sharing options...
Dd9515 king Posted September 15, 2013 Report Share Posted September 15, 2013 Clamping is accurate with good meters. When you clamp you see what power your subwoofer is getting. On the dyno it only sees what your amp makes at that ohm load. The dyno is great to see what it makes at that load. A subwoofer is a reactive load it changes with the tuning box size pressure on both sides of the cone etc. A clamp test shows what your amp is making at that frec. to your subs. If you take the same amp on the same external power wired to the same 1 ohm nomial load on the same woofers in the same box in two different cars. You will come up with different clamp number because the changes you made. Link to comment Share on other sites More sharing options...
Wicks Posted September 15, 2013 Report Share Posted September 15, 2013 Clamping is accurate with good meters. When you clamp you see what power your subwoofer is getting. On the dyno it only sees what your amp makes at that ohm load. The dyno is great to see what it makes at that load. A subwoofer is a reactive load it changes with the tuning box size pressure on both sides of the cone etc. A clamp test shows what your amp is making at that frec. to your subs. If you take the same amp on the same external power wired to the same 1 ohm nomial load on the same woofers in the same box in two different cars. You will come up with different clamp number because the changes you made. Do some research on phase angle. Those peak measurements on your meters are not happening at the same time. A resistive load is the hardest on an amplifier. An inductive load (speaker) will have higher impedances throughout its frequency spectrum and therefore be a lighter load. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
Dd9515 king Posted September 15, 2013 Report Share Posted September 15, 2013 I was meaning if you played a sine wave at like 45 hz. If you burp amp it will be different. If you take steve test bench for example. Have everything hooked to the bench nothing to the car. Take the box from one car to the next playing the same 45 hz tune. Link to comment Share on other sites More sharing options...
David Posted September 15, 2013 Report Share Posted September 15, 2013 Tony D just proved that clamping isn't accurate. Link to comment Share on other sites More sharing options...
David Posted September 15, 2013 Report Share Posted September 15, 2013 And me personally, I'm gonna listen to the engineer over anyone else on this site. Link to comment Share on other sites More sharing options...
