AlpineNut Posted September 16, 2013 Report Posted September 16, 2013 All i ever hear is use 0/1 Gauge for the Big 3 wiring upgrade for the vehicles. But my Question is why, I have a 2005 Silverado and did the Big 3 Upgrade with 4 Gauge and the runs are not more then 3 feet in length, so what is the difference? Below is a picture. 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n
Watch the bass Posted September 16, 2013 Report Posted September 16, 2013 Current can better flow in bigger wire = lower resistance, that´s physik. "in the abundance of water, the fool is thirsty" Bob Marley
Tribe Called Bass Posted September 16, 2013 Report Posted September 16, 2013 It also makes the current flow put less stress on your componets. Helps disperse the power.
NathanW Posted September 16, 2013 Report Posted September 16, 2013 To be honest I don't think you really need 1/0 for all three of the big three. The engine ground doesn't need to be that big and the alternator connection only needs to be large enough to handle the output of the alternator. The main connection you want to worry about is the chassis ground because that connection will go directly to your amps whereas the positive power will come from a cable run (separate of your alternator run) directly from your battery. And of course make the positive power run to your amps the largest you can afford. '99 Chevy Blazer 4 door 4x4 HU: Pioneer, DEH-80PRS Front Stage: Hybrid Audio Technologies, Legatia L3v2 and Dayton Audio Reference 7" mid-bass Sub Stage: Hybrid Audio Technologies, Clarus C12SW-D2 in a 30hz quarterwave transmission line (plays down to 17hz!) Amplifier: Addictive Audio 7.4+35.1 Processor: Zapco DSP-Z8
CleanSierra Posted September 16, 2013 Report Posted September 16, 2013 It doesn't sound like you had much of a question, or cared for one for that matter. Bigger wire equals less restrictive flow of electricity. Less restriction equals less heat. Less heat equals less power loss through your cable. You aren't upgrading your Big 3 so the vehicle performs better than factory, they already determined what would be needed and used appropriate sized wire. You're upgradng since you have changed the demand on the vehicles charging system and need it to be more efficient for the aftermarket system. Im not the one you want to try to troll. Just a fyi for you.
afrakes Posted September 16, 2013 Report Posted September 16, 2013 Just to add, it's correct that not every application requires 1/0 to keep up with what you are running. But why take a risk when there really isn't that big of a price difference? It's not very much wire at all when talking about the big 3, but why add the trouble of upgrading ur big 3 every time u upgrade your system? That's just throwing money away. Yes, 4 AWG will prolly do the trick, but while ur in the nitty gritty of the install, just do it right the first time. Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
john253a Posted September 17, 2013 Report Posted September 17, 2013 Most wont tell wire is not only rated by amp but length, there is calculation to work out resistance over length at (x) amps If you wanted to say push the limits both ways 4g cable is rated at 10amp or 250amp but at different length At 2ft and under 4g cable is suited for 250amp @12v And at 50ft it is only rated for 10amps @12v Same as why they use 4x2 to frame a house and not 4x4 or 6x4 because its not always required and money well spent else where If you not upgrading factory alt 4g is a good choice, easy to run and very cost effective If you plane to upgrade alt or have done so Then anything <1/0 is required
AlpineNut Posted September 18, 2013 Author Report Posted September 18, 2013 No the Factory Alt is stock at 145A which i find suits my needs for the 2 amps i am running. but one thing does pose a small weird conundrum i noticed. When i had 2 8 gauge wires running from my Fuse from the battery the lights if at ever barely dimmed and the system sounded as it does now, but ever since i changed to 1 single 4 gauge the lights dim more, this is a confuser, only thing i can think of is the amps were on there own power line and not feeding off of 1, but i also had 2 separate 8 gauge grounds also and now it is still 2 grounds but both are 4 gauge. And yes the paint is scrapped off of both grounding points! 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n
john253a Posted September 18, 2013 Report Posted September 18, 2013 the bigger cable now means that you can supply the power required to the amps, hence now dimming more where as before, as the cable would have been restricting the supply before but youll need to upgrade your battery and or batt and alt to fix the voltage issue idd atleast want a 3100 or similar up front
kirill007 Posted September 18, 2013 Report Posted September 18, 2013 Why not spend 5 bucks more for double the performance? You have less voltage drop, the wire will heat up less with the same amperage going through. Thinking is the root of all problems... You ALWAYS get what you pay for.
