Tony just said they both gain resistance linearly so that doesn't make much of a difference.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
The resistance of both OFC and CCA increases linearly with temperature at approx the same rate with temperature. Both cables same temp increase = same percentage of resistance rise. So the CCA would continue to have the same disadvantage no matter what the temp, if both were the same temp. BUT in reality, CCA is going to lose again because Aluminum has less capacity for heat than copper. Meaning take the same size blocks of both aluminum and copper, put exactly the same amount of heat into them for exactly the same time. Now measure the temp of the two metals, the aluminum will be hotter. So in the real world the longer you play it the worse the CCA will be. This is why expensive audio amplifiers use copper heatsinks, as do computer parts.
Yeah I didn't read the second half of this response
Do a test with a 20 ft run of power on each so it is how it would be in a car. 1 run CCA vs 1 run OFC
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
What if instead of 3 runs of CCA vs 2 runs of OFC you did 1 run of OFC vs. a 0ga and 4ga run of CCS
I would also like to see 15+ foot run tests. Could be slightly wasteful on wire if it was fresh but CJ you have enough wire laying around. I'm sure you got enough to test this with out ruining rolls
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
If I have plenty of extra wire left after I install everything in my truck I may run another test with longer runs. I cant keep cutting off of my spools until I have everything installed.
Starting voltage/certified 1 ohm/ tested voltage
Test is done on dc 3.5k
Each run of wire is 52" long
1 run 1/0 cca
14.83v/2987w/13.56v
2 runs 1/0 cca
15.13v/3175w/14.11v
1 run 1/0 ofc
14.95v/3131w/14.02v
1 run 2/0 ofc
14.91v/3274w/14.16v
If needed, I have video of each test for verification.
Based on these numbers, taking wire cost out of the equation and just going wire by wire, I take the single run of SHCA 2/0 OFC all day. It had the lowest amount of voltage drop along with the highest power output.
How do dual inputs stack up against just 2/0? So like dual input 1/0 vs 2/0? All OFC and need test copper dual vs alum dual. :)
Evo X build log
  • Who's Online   1 Member, 0 Anonymous, 3158 Guests (See full list)
