The right cap on goof electrical and installed correctly has been shown to be a benefit. Although I doubt you would be able to find a good enough cap for less than a second battery.
As everyone already said big 3 in 1/0 gage wire. Run a 1/0 run back to 1-2 batteries in the trunk and from them use the proper gage wire for the amps. Also remember to fuse every wire accordingly.
Edit: that's a lot of power off a 130 amp alt IMO.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
9v and i 1000 watt amp? I ran a dc 3.5k at 1 ohm with stock electrical for a couple days, lowest I saw was 10.9 if i remember right. Not saying that 10.9 good but damn 9?
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Are you excessively clipping? I know when I hard clip I'll drop basically an entire volt.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
THIS^. when i go from songs i know have some clipping i go from holding 13.7 to down to 13.0 full tilt.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I would like some legit proof from someone in the thread that playing below 12v, 13v, 14.4v or whatever some claim is actually harmful to amplifiers. And no "it makes teh signal dirty" is not proof.
Everyone always says that low voltage is bad for amplifiers, but never actually explains why.
Now batteries, I can see why you wouldnt want to go below 12.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
do big 3 then get a ho alt I don't why no one said anything I would get a ho alt before a second batt a 200amp alt should be fine then get a second batt.
here the list that I would do:
1/0 wire
big 3 with 1/0
ho alt
replace hood batt
add second batt.
if you have to add a third batt try getting a bigger alt then 200+amps first.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Ill get around to doing the big 3.
This is a split second it drops to 9vlts then goes back up. Again it's if I'm seriously bumping!
I will be removing the cap.(which I think is my problem) it's the cheapest part in the build.
The patherfinder has a 3.3l so I'm thinking it's like a 90amp alt.
I'm advance guys I'm VERY new to the game. This is just a simple build from a 19 year old who father brought him up on rockforge who is no longer around to help out when it starts to get serious. Haha
  • Who's Online   0 Members, 0 Anonymous, 760 Guests (See full list)
