Swordlordboy1234 Posted September 19, 2013 Report Posted September 19, 2013 Terry is also a SPL fart box guy. If you plan on playing 40-50hz burps or you have one of those special cars that don't gain by sealing. Then awesome. 90% of the time it's better on music! louder, and lower. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
OBI Posted September 19, 2013 Report Posted September 19, 2013 Terry is also a SPL fart box guy. If you plan on playing 40-50hz burps or you have one of those special cars that don't gain by sealing. Then awesome. 90% of the time it's better on music! louder, and lower. You just made this post just to argue! Then proved my point!
Swordlordboy1234 Posted September 19, 2013 Report Posted September 19, 2013 Yeah, so if a person asks if they should seal. The reply is yes unless they test differently. And then add their model car to the list of cars that don't gain... Which is 3 that I know of. How many cars do you know of vs how many trunk cars are on this forum. .? My point. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
soundstream15 Posted September 19, 2013 Report Posted September 19, 2013 I just sealed my trunk off, it's not 100% yet but it's also hard to get 100% if you want numbers and really take the time then you can do 100% I have a 2 door grand am. Now when I open my trunk the higher bass is louder but once thing I did gain was lows, is it louder? Yes a little but it sounds better bc no trunk rattle. It takes time to seal the trunk off. Depends on what you use. I still ain't sure what to use besides spray foam and gorilla tape. It's well worth it tho.
OBI Posted September 19, 2013 Report Posted September 19, 2013 Yeah, so if a person asks if they should seal. The reply is yes unless they test differently. And then add their model car to the list of cars that don't gain... Which is 3 that I know of. How many cars do you know of vs how many trunk cars are on this forum. .? My point. Yes if you are going for the loudest possible setup for your car. Musically or Fart box. I guess if you don't care just seal it off and hope for the best.
David Bailey Posted September 19, 2013 Author Report Posted September 19, 2013 I am only running two 12's with 1200 watts.. I want it to sound good, not super loud. I am thinking sealed is the way to go, should sound better and look a lot better too. Did you get that scar tissue when you got your vagina installed? KNOWLEDGE DESTROYS FEAR Measure twice, cut once JVC touchscreen HU Mmats E600.4 Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
Swordlordboy1234 Posted September 19, 2013 Report Posted September 19, 2013 It hardly ever hurts to seal off. If you are one of those lucky cars then you have no DB gain and it just looks cooler. So your either yon gain and look better or you don't gain but don't lose and look better. Sounds like sealing doesn't have too many negatives, why not try it? It worked for me and many others. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
DubNDodge Posted September 19, 2013 Report Posted September 19, 2013 Yeah, so if a person asks if they should seal. The reply is yes unless they test differently. And then add their model car to the list of cars that don't gain... Which is 3 that I know of. How many cars do you know of vs how many trunk cars are on this forum. .? My point. I can think of one, mustang. What are the other two? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
slowfkncar Posted September 20, 2013 Report Posted September 20, 2013 Wait,I did a 2007 mustang with two 10" sundown sa-12s and I swear it sounded louder after I sealed the trunk from cabin,I mean COMPLETELY sealed. but I have not actually measured the output (customers vehicle)
