rockford 1200.1D is melting wires.
whatusay45
The entire wire and the distro block is too but the other wire gling to the other amp isnt neither the grounds nor the battery positives just that one wire
which is the other amp? the other rf 1200? or the 4 channel?
So you have 2 amps that realistically can draw 120A per amp. You've likely got at least a 200W(if running at 4 ohms) 4 channel amp also, so there is at least another 20A, possibly more like 40-50 amps at full tilt.
So to wrap up, you've got probably 240-260A of current demand. 4 gauge isn't gonna cut it dude, you're into 1/0 OFC range, not 4 gauge CCA. It doesn't matter what feels warm or if the other amp is working or not. You need a run of good 1/0 gauge and then split to 4 gauge at your distribution block.
To be absolutely clear, the wire that is melted is the B+ right?
And those fuse blocks suck. Connections are always crappy
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I noticed connections are always comming lose
I'll bet that's what it is. Poor connection causing heat. Get a distribution block with some hex-key set screws.
Confirming... Is the entire wire HOT or just the portion near the fuse/distribution block?
And I'd upgrade the wire going in to 0ga or add another 4ga in IMO
I'm confused by your pictures.
In this picture there is no ground going to the nearest amp. And a random ground and power not hooked up going somewhere towards the front of the car and it looks like you have the power wire going to ground on one amp and power on the other. It also looks like you have no charge wire going to your battery at all.
In this picture your distro block clearly has two inputs and two outputs and you have plenty of wire to run two runs off that battery yet you only ran one to it.
What is going on in your trunk man?
edit:spelling
