What is Your Favorite Car Audio Tip or Trick?
if you need to run a thin wire through firewall or dash then straighten a metal hanger, then tape the wire to the hanger and run it through that way.
Or buy a grommet tool? hehe
yeah, obviously if you dont have one.. hehe obviously.
TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET
150Db Club
160Db club in the future
I see krakin as a threat
homemade tweeter savers
a standard car dome light in line with your tweeters positive terminal. It acts like a resistor that changes impedance as it gets hot and starts to glow. When the impedance rises, it causes the amp to put out less power, keeping the tweeter in check. If you push it too hard still, the bulb will pop and NOT the tweeter. Get a new bulb, set your gains better, and you are back in business. click here for an example. http://instagram.com/p/bzLpBJEt1w/
  • Like (+1 Rep) 3
Follow my Tweet (Twitter)
low power 4 channel amp install in a car with rear deck speakers. jump the wires on the harness. you just need to run wires from the amp to the rear deck speakers and the leads that are now for the front speakers.
using a small piece of electrical tape to wrap around a drill bit to create a drill stop at any depth.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
mix mdf sawdust with wood glue to make your own mdf putty.
i bet that would be strong as hell,what are some uses?
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
fill gaps... seal edges/corners
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
I do it for securing the inside gap of aeroports in boxes or to supports.
Krakin's Home Dipole Project
Soldering all connection! Crimping as little as possible. Needless to say its a much stronger and more connective connection that won't come apart due to vibrations.
You guys at sonic are awesome, I always shop there. Keep up the good work!
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
Also proper gauge wire for application, using ofc not CCA, proper fusing, sanding paint off grounds and then covering it with a conductive lubricant so it doesnt rust. All I can think of for now
Car: 2000 Honda CRV
will this work if you gave a bass blocker on the positive lead also
2009 bmw 5 series
Head Unit Stock
  • Who's Online   1 Member, 0 Anonymous, 1224 Guests (See full list)
