I just purchased a long needed Iraggi 220amp alternator and lately my volts has been at 10.9-10.8 with out the system on so i know the alternator is NEEDED! but my question is what are your volts with your HO alternator? I have a HC200 under the hood and a everstart MAXX deepcycle in the trunk on 2 hk401sx's and a JBL75.4 and im hoping my volts will stay around 13.5 or more with the HO alt...think so?
How much watts are you running?
How many batteries?
What size alternator you have?
What is your volts at full tilt or bumpin hard?
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
(260 Amp Iraggi Alt) 14.4-14.8 at idle or moving but when I'm in drive and stopped at a light it sits at about 12.2-12.5. When I'm hitting hard the voltage will drop to about 13.3-13.7.
Oh I forgot to add that I'm only using 1 Yellow top that sits at 11.9 (yikes!!!) when the vehicle is off!!! Also my Big 3 is really the Big 2 so its really my fault. I know that my electrical is sucking right now but in about a week that would be updated!!!
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
nsb 90
200amp alt
big 3
1200watts
it doesnt drop below 12 at idle and stays above 13 when i have it reved a little bit (like 2000rmps)
i likes me some audio stuff...
4 alts totalling over 1300amps
7 D3100 batts
23,000 watts rms (birthsheet ratings so it varies of course)
playing enough to hurt most people 14.2-14.4 during play (full tilt but backed off a hair)
playing full tilt 13.8v
each of my bass amps tries to draw 400amps so i think those are pretty good numbers for what i have..23k and i only drop .8 volts at full tilt. (14.6v average with no music playing)
Follow my Tweet (Twitter)
I just purchased a long needed Iraggi 220amp alternator and lately my volts has been at 10.9-10.8 with out the system on so i know the alternator is NEEDED! but my question is what are your volts with your HO alternator? I have a HC200 under the hood and a everstart MAXX deepcycle in the trunk on 2 hk401sx's and a JBL75.4 and im hoping my volts will stay around 13.5 or more with the HO alt...think so? Yes, it will help alot, but ur alt is used to supply enough power to charge and recharge ur battery(s)... so personally, i think u need at least another deep cell, i dont like everstart but if u do cool. Just using something as simple as Kinetiks Power Calculator it says u need a hc1400 under the hood and 2 hc1400 near the amp... this is what will stabalize ur voltage closer to 13-14v (which mathmatically could be another 400w going to da woofers)
So that'd be like having three of ur everstart maxx bats
hope that paints the picture a little better
2001 Navigator
How much watts are you running? 2000wrms Hifonics bxi2000d (so more like 1800w)
How many batteries? 2 stinger spv1700
What size alternator you have? rebuilt 220a
What is your volts at full tilt or bumpin hard? resting 12.8 car off, idle no music 14.4, idle w/music 13.6-13.2, rpm@2000 no music 14.6, rpm@2000 w/music 13.9-13.8
and
2001 mit ecl
~1400-1600w (rf1000bd+rft400-4)
200a EA alt
resting 12.8, idle 13 (alt doesnt kick in til about 1000rpm, idle is 700rpm), idle music 13, 2000rpm no music 14.7, 2000rpm w/music 13.1-13.4
7 D3100 batts
thats bad ass steve, watchin how much that volt meter DIDNT move was almost as awesome as checkin all the stuff out in person, lol
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
and
2001 mit ecl
200a EA alt
I have a HC2000 under the hood and was going to get hte HC2400 but i cant afford it right now so this everstart MAXX wil have to do
_____________
And from what everyone is say i should be good considering im only drawing like 140-160 amps..then i can actually get another JBL75.4 and 2 kx2500.1 instead of the MA's
TEAM DEADLY HERTZ
I would think if its dropping voltage like that, I would check tension on your belts, maybe the Belt idler started losening up, and it doesnt have the grip to the pulley on the alt like it should
Just a guess....
if not check wiring for a losened bolt ground, or Pos
if all good, take it up with Iraggi
i currently have my stock 50 amp alt, a red top duralast upfront, 2 interstate workaholicks and 2 stinger spv35s in the rear,.
and my voltage is 14.2 full tilt
and my amps are poweracoustik 5500d and kicker 850.4
Edited by mrwigglezdj
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
  • Who's Online   0 Members, 0 Anonymous, 4391 Guests (See full list)
