remote wire help!!!!!!!!!
I need help I am installing a friends system in a 2010 ford fusion and she has a factory head unit (which she refuses to replace) where and how should I run the remote wire. I don't want to tear apart her dash to get to factory head unit. i need help!
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
You are going to need to pull the unit as far as I know, unless you got some skinny arms.
Krakin's Home Dipole Project
kinda hard to install a system if you aren't willing to do the work to get to a simple remote wire. I was going to suggest using the ACC wire instead but i didn't want to trouble you to look for that either LOL
Follow my Tweet (Twitter)
i am willing to do the work but she dowsnt want me gtaking apart the dash so if there is any other ways please tell me and yes i do have fairly skinny arms
If she doesn't want the dash coming apart I think she needs to ask herself if she really wants audio. That's like saying I want haircut but I don't want you to touch my hair..
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
The dash goes back together after your done.
Unless she doesn't trust that you know what you are doing.
Anyway, you can use an ACC or ignition wire that can be found behind the radio, or under the dash.
Or if you are using a line output converter, some have a remote that turns on when it senses Audio signal. Some amplifiers have that built in as well.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Exactly what are you installing?
The remote wire is just a 12 volt signal that tells the amp when to turn on and off. When it has voltage the amp is on, when it doesn't it turns off. There are a whole bunch of ways to do this. All you need is a wire that only has power while the car is running, like several people have already mentioned, the acc wire under the steering column is an option.
Another option, although I would not recommend it, would be to run a hot wire with an inline switch. I wouldn't recommend this because she will most likely either forget to turn it on or off when she should. Forgetting to turn it on means she would have no beat and forgetting to turn it off could drain her battery.
i know what the remote wire is and i was thinking about running a swich as a last resort i was just trying to find another way to run the remote wire with out taking the hu out. i am going to try to find the acc wire on monday. i know how to take everything apart but i am trying to avoid doing that if i can.
I think either way your gonna have to take something apart.
You are a true friend because i would have bailed on that job as soon as she said she don't want you to take the dash apart.
Let her read some of the post and she may change her mind.
Good luck.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
