Engine noise from amp
I just got done making door pods and used some 6 gauge I had to run for power hooked up while I am waiting on my new power wire to come in. I have to power on the front bat and the ground is the same as the ground I use for my SQ2200, but for some reason I have a ton of engine noise coming from the amp. We thought maybe is was the RCA's so we swapped those out but the noise was still there. Anything I could have missed? The amp is a SSL 400.4 (just bought it to run a small sub in my room) and I will be getting a MB OA800.8 soon
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Ground your HU to the frame
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
check groundings of ur amps, make sure + - wires are not to close to each other.. same thing with speaker wires.. check all connections.. try grounding RCA's ..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
what kind of hu is it and also it could be a ground issue
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
It's a Sony MEX-BT4100, although I've never had this problem with it. And as soon as I take the RCA's out do the front amp there is no more noise. As soon as my new wire comes in I'm gonna take up my carpet and re run everything
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I'll try spreading out some of the wire to see if that's it. The power, ground, and speaker wires are all running beside each other
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
so whats new to the setup that could be the cause of it
2 sundown sd-2 d4
flex tech
box design by Joe X
I might have a rear in the speaker wire I ran for the subs and I will check that when all the new wire comes in. I took the positive and negative to the SSL and hooked it stright to the rear battery positive and negative. Pulled the speaker wire out so they were by themselves along with the RCA's and still had noise. I'm thinking now it's the amp bc I got it for $35. I honestly don't know what else it could be.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
probably the amp then I had a ssl f1400.2 it was rated at 200rmsx2 @2ohm it sounded good for a $70 amp
2 sundown sd-2 d4
flex tech
box design by Joe X
I had an issue similar to this and what I did whas grounded my rca's because something internally with grounding on the headunit went bad.
eventually got a new headunit,
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
