Some Questions About Grounds.
So my setup consists of an xs power d3400 under the hood and an xs d3100 in the trunk. The 3100 has 2 grounds that are on some metal in the trunk, but I found that these are not good enough grounds. So I plan on running 2 runs of 0 gauge from the negative on the 3400 in front to the negative on the 3100 in the trunk. Is this all I need or should I keep those 2 grounds in the back as well as the 2 front to back runs. Thanks
you don't have to run wires to the back battery just ground them to a solid metal or frame but alot of people due one run to front to back and the back batt run an extra to a frame or something solid metal.lesson here the shorter the grounds the better.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
hes right..grounds should be as short as possible.and ground to bare metal..remove any paint at gounding location
You need trunk space to get groceries and shit...bitches love groceries
Ground wire from front to rear batt is not strictly necessary as long as the chassis grounds have VERY good contact to bare metal.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
Screwing into the metal just doesn't cut it either. I like to run a bolt as well as a nut to make sure it's solid. Especially with sizes 1/0 or bigger.
Same.
I like to thread the drilled hole, then, run a stud through it, THEN, add eyelet, and bolt/wish lock, or no spin washer. Secure, and making contact in 58 ways.
Also, dunno about your vehicle, but i found, BIG BIG difference in material thickness through out my frame. I found a boxed, and trussed section, and went there.
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
