STEvil Posted October 20, 2013 Report Share Posted October 20, 2013 2 channel amplifiers see "half" the impedence when run in mono mode. 8 ohm mono is effectively 4 ohms. 4 ohm mono is effectively 2 ohms. 2 ohm mono is effectively 1 ohm. These are the wiring options for your single D4 sub: 4 ohm stereo: 100w+100w 8 ohm mono (amp sees as 4 ohms): 400w 2 ohm mono (amp sees as 1 ohm): not recommended MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted October 20, 2013 Report Share Posted October 20, 2013 Shouldn't that be 8ohm mono 200watts? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted October 20, 2013 Report Share Posted October 20, 2013 My sub is dual 4 ohm. Rated Power: 100W x 2 @ 4-Ohms RMS; 200W x 2 @ 2-Ohms RMS; 400W x 1 @ 4-Ohms bridged Wouldn't running it 8 ohm bridged be the same power as 4 ohm stereo which is 200W and is half the rated power that it would run at 4 ohm bridged? Now I don't feel so dumb. See post #3. Amp/Sub not a good match bud. Best way to do it is to run a coil per channel and call it a day until you can get a better match one way or the other. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
n8ball2013 Posted October 20, 2013 Report Share Posted October 20, 2013 It will not like it Not a good idea I wouldn't try it Where there's smoke there's fire THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
bcbrassard Posted October 20, 2013 Report Share Posted October 20, 2013 OP,stop trying to get the most wattage out of the amp and try to get the best sound with what you have until you can upgrade. Link to comment Share on other sites More sharing options...
STEvil Posted October 20, 2013 Report Share Posted October 20, 2013 Shouldn't that be 8ohm mono 200watts? 100 watts RMS x 2 at 4 ohms (200 watts RMS x 2 at 2 ohms) 400 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode) MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted October 20, 2013 Report Share Posted October 20, 2013 So yes? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
STEvil Posted October 21, 2013 Report Share Posted October 21, 2013 No, unless they wrote the 4 ohm bridged output wrong and meant 2 ohm bridged (effective). MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
kr15 Posted October 21, 2013 Report Share Posted October 21, 2013 8ohm will be 200x1, same as the 4ohm stereo channels summed. 4ohm will be 400x1, same as 2ohm stereo CHs summed. Since he has dvc4, he can wire 8ohm mono, 200w, or on 1 2ohm stereo CH, also 200w. Those are his options for not running under impedance. Team Flex Issues Low tuning > God 2011 CALI AS1 STATE CHAMP Link to comment Share on other sites More sharing options...
MrSkippyJ Posted October 21, 2013 Report Share Posted October 21, 2013 8ohm will be 200x1, same as the 4ohm stereo channels summed. 4ohm will be 400x1, same as 2ohm stereo CHs summed. Since he has dvc4, he can wire 8ohm mono, 200w, or on 1 2ohm stereo CH, also 200w. Those are his options for not running under impedance. this sounds right to me. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
