Cheapest way to ACCURATELY set gains?
Brandonbkd
Is there a cheaper way than going out and buying a dd-1 or oscope?
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
DDM or set it up ear. No it won't be perfect. No it won't be accurate.
That's the risk, but just be smart and you shouldn't hurt anything.
Eclipse cd7000
Find someone near you with a DD1 and go visit them to have it done or go to a shop with an OScope and have them tune it for you.
I looked at that map a while back that shows people near me with that stuff and I think the closest was a few hours away
FI BL18
Pioneer DEH-2500UI
Pioneer 6 x 8s
5 ft^3 box at 35hz
Lots of Mega Mat
Hope and prayer
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
A nano scope is like $70 on amazon. If that's out of your budget car audio might not be the hobby for you
Used to have a loud truck
Then I would look up every reputable shop in your area and find out who has the OScope then go and have it tuned properly. The by ear method does work (for some) but I would not recommend it to anyone who doesn't know what they are doing because it could cost you a lot of money in blown equipment.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
I saw some of those but I didn't know if they'd work well or if they were just a china piece of junk.
FI BL18
Pioneer DEH-2500UI
Pioneer 6 x 8s
5 ft^3 box at 35hz
Lots of Mega Mat
Look up your amp to see if it actually does rated. See if someone bench tested it and posted results or look at your or someone elses birth sheet if they are availible for that amp. Once you have an idea what kind of wattage your amp should be putting out use the DMM method but subtract like 5-10% wattage just to be safe.
This is probably as accurate/safe as you can be while being a cheapass. You will probably be able to get a bit more out of the amp with dd1/oscope this way, but not much and its a neccesary sacrifice so you don't blow anything up.
You can set gains with a VERY basic oscope. Even a super old one from the 80s or something. Audio stuff is a very basic thing for an oscope. The really expensive ones you see are probably ike 350mhz+ models. You don't even need 1mhz for audio.
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
