pioneerforlife Posted October 19, 2013 Report Posted October 19, 2013 So within the next month I am going to be building a box for 2 12's. I have been planning it out and decided to paint it a gloss black with round over edges. so my question is, how can I get the paint to stay consistent over glue seams. I am going to use primer and plan on using rustoleum gloss black paint. In the past I have painted my boxes and the problem I would have it the past is that the paint would appear different on the areas where there was glue. I have used gorilla wood glue but plan on using titebond. thanks in advanced. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
Cox Posted October 19, 2013 Report Posted October 19, 2013 From my experience it's the not glue you have to worry about, it's where you round over that's a bitch. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
pioneerforlife Posted October 19, 2013 Author Report Posted October 19, 2013 ^^in what way. just because of the shape of it? 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
thefourth Posted October 19, 2013 Report Posted October 19, 2013 Sand the glue down the best you can and put a little bodyfiller over it and sand it smooth. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
revoracing247 Posted October 19, 2013 Report Posted October 19, 2013 you can use body filler or just spend $20 on some homedepot fiberglass resign and resign the box. then sand that. it's what i did and it worked out pretty good.... ~ If it was easy, everybody would be doing it ~
revoracing247 Posted October 19, 2013 Report Posted October 19, 2013 i've also heard that priming it and then sanding it just a bit and then painting like normal from there works. but i haven't tried that method yet so i'm not endorsing it. ~ If it was easy, everybody would be doing it ~
Soccerballzs Posted October 19, 2013 Report Posted October 19, 2013 Woodworker here you need to final sand mdf with 180 grit then go to Sherwin Williams buy lacquer sanding sealer use 2 to 3 coats sanding between coats with 220 grit. Should turn out beautiful. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
pioneerforlife Posted October 19, 2013 Author Report Posted October 19, 2013 you can use body filler or just spend $20 on some homedepot fiberglass resign and resign the box. then sand that. it's what i did and it worked out pretty good.... that is the exact look I am looking for. so you just resigned the outside of the box, sanded it down and painted it correct. no primer or anything? Woodworker here you need to final sand mdf with 180 grit then go to Sherwin Williams buy lacquer sanding sealer use 2 to 3 coats sanding between coats with 220 grit. Should turn out beautiful. I may have to go check that out this weekend. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
n8ball2013 Posted October 19, 2013 Report Posted October 19, 2013 The issue is where an exposed cut edge is. The cut edge will soak up paint like no other THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
tacomaguy1 Posted October 19, 2013 Report Posted October 19, 2013 What he said, like a sponge. With the glue it will soak in and seal that spot wherever it is. So around it will soak in, the glue spot wont making it look off. Whipe off all excess glue while its still fresh helps Team Flex Issues
