MMMM an Audio Multimeter with built in handheld amp dyno. Real world, real time wattage. All you need is your own load (aka speakers).
now available and in stock!
http://www.wccaraudio.com/smd-products-29/smd-tools/smd-audio-multimeter/smd-audio-multimeter-amm-1.html
EDIT: Now available on Amazon! click here http://www.amazon.com/SMD-Audio-Multi-Meter-Amplifier/dp/B00LNU1ELK/ref=sr_1_17?s=electronics&ie=UTF8&qid=1404967514&sr=1-17
all the things an audio guy NEEDS in a DMM without the stuff you DON'T need. The AMM-1...
  • Like (+1 Rep) 2
Follow my Tweet (Twitter)
Going to shoot you an email on this thing Steve.....need to pick one of these up and some more of my favorite resin :) I'm spoiled now haha
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Here is the important pages of the owners manual. Check them out, get a feel for how it operates.
A short video of it booting up and going through the menu. I will make more demo video's of how it works...of course, you can look at the original prototype vid (page 1) and see for yourself some of the great features.
only thing, i wish it didnt stop its true power dyno at clipping. some/most competitors go into clipping, so this would in turn give them a unless number (not completely useless), but you get the point. it would be cool if it was possible to be able to include or omit the clipping stopping point.
You can read clipped power. On the VA and Power Factor screen, the VA reading isn't limited by the clipping detector so you can just take the VA number and multiply it by the Power Factor % and you will have Watts (clipped or not)
Just wanted to take a minute to describe some of the differences between the AD-1 Amplifier Dyno and the AMM-1 Audio Multimeter
The AD-1 Amplifier Dyno can do these things that the AMM-1 cannot do:
1. Measure Amplifier Output into a purely resistive load bank
2. Measure Amplifier Output until 1.0% THD is reached
3. Measure Amplifier Output into 10 different load impedances with the touch of a button
4. Measure Amplifier Dynamic Power Output (IEC-202 Standard for headroom)
5. Capture the exact B+ Voltage that was seen at the amplifier at the moment the last power reading was made
6. Two DD-1+ built in.
7. Measure amplifier output in car using resistive load bank vs your speakers, this provides VERY consistent measurements so the effects from changing things like a better B+ power cable, better ground, better battery etc can be easily and accurately measured
This is the exact type of testing the the factories use when manufacturing the amplifiers, and meet CEA standards. They are very defined tests with strict rules.
The AMM-1 Audio Multimeter can do these things that the AD-1 cannot do:
1. Measure amplifier power into your speaker load, both apparent power (VA) and true power (Watts)
2. Measure impedance of your speaker load at any freq from 20Hz - 1kHz
3. Measure the current vs voltage phase shift of a reactive load (Power Factor)
4. Measure the DC Voltages like a multimeter
5. Super fast DC Min/Max for measuring drops and peaks of a DC voltage
6. Measure the Power CONSUMPTION of AC powered devices, like microwaves and light bulbs for example
7. Find the tuning freq of your subwoofer box, box rise and such
That is a short summary, I'll be checking when I can to answer any technical questions about the product.
Thanks!
Tony D
Edited by TonyD'Amore
  • Like (+1 Rep) 2
dmm paired with a handheld amp dyno packed into a dmm case?
check voltage, check resistance, impedance, real world power, plus more. Should sell real good.
Edited by alaskanzx5
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
no...it's not a DD-1 at all.
