Door Panels: Starting New 02 Civic
Pod fits in there nice! Flows nicely with the panel!
AND IT LOOKS SEXY AS HELL
Lmao, true, true!
Firm believer in letting my cars do my talking!
You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it.
"Black Pearl" Build Thread
http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1
Next is to Secure the Pod on the Door. Just prying it in there is not enough, when the vibrations from the lows start it will giggle loose. So first to protect the door panel front and back.
Locate the pod in its place (tight fit) and Protect the front of it with tape as well so that only the backside of it is exposed
and then apply several layers of glass on the pod's back that stretches along the shape of the back of the panel. All the curvatures and fins and extra stuff on the backside serves as a way to hold the pod in place once it's dry and shaped and it also makes it so that it's a one way fit only.
So after you let the Fiber dry overnight. Peel out the piece, tear out all the blue tape. Trim the piece and test fit it
The night before
the next day, piece pulled out
you can see all the crevices and curves that will hold the piece in place. It actually pops into and out of place.
the Piece all trimmed up
and test fitted on the door. The Back side
and the front. also taped up some areas and applied duraglass on the edges to get that clean tight seam look.
now a little body filler on the pod to match the curves to the shape of the door.
That is a ton of work but looks real good.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Ya. the 500 hr doors! LOL But...you cant rush perfection.
What's you plan for the pods for finish? Paint, material, or CF?
Paint. Go to page 5, the tweeter pods and the mid's section will be that champaign beige with purple pearl which is the color of the car. The rest of the door panel will be that black with purple pearl. The top part of the door that you see missing, the arm rest area and the ring I made are all C.F.. and the Insert area will be a beige Alcantara suede. And there are L.E.D'S everywhere both purple and red.
