Optima 1 year old, going bad??
Hi, I've been recently having potential battery problems. I bought an Optima yellow top about 1 year ago from eBay new and it has always sat around 12.6 volts resting in my car. Just a month ago it started going lower and lower. It is currently at 12.1 resting almost everytime I jump in my car, even after just a couple hours after the car has been driven. Could my Optima be dying?? I paid $174 for it and they are suppose to be solid as a rock, so I wouldn't think so.
Also, my alt has always charged it anywhere from 13.5 to 13.8 volts and has recently been higher around 14.2 volts. It is only ~32 degrees outside and is going to get much much colder. I have a RF T1500-1bdCP @ 4 ohms and a T600-4 @ 4 ohms with a RF capacitor. Stock 130 amp alt. Optima is a D34 group.
Any thoughts or info on this matter? Any input would be greatly appreciated!!
'98 Chrysler Concorde LXi
Pioneer DEH-80PRS (HU/processing)
Rockford Fosgate T1652-S (components) for front
Rockford Fosgate T1693 (6x9s) for rear
Rockford Fosgate T600-4 running those
Rockford Fosgate T1500-1bdCP running a
Rockford Fosgate T1D215 15"
in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)
Kicker PKD1 (0 & 4 AWG)
stock 130 amp alt for now; One yellow top Optima
Installed everything myself & built box (brother helped)
Used a DD-1 to set gains.
Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/
Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
Sounds like you system is graving more power. May need to upgrade to bigger alternator or a D31000s in backs. Battery is not charging because system is taking all the power.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
optimas WILL just up and die. had it happen to me. IIRC N8 also had it happen in his truck just as he started his wall.
pull it out and load test it, just becasue it shows 12.X volts doesnt mean its good. it could drop to 1v while loaded down
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I have a new one 8 months old on floor of garage just not like a XS Power battery.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I did have one go out but it was one of the older new ones I had. It went out after the wall was in though so I had to dig it out from under the wall. It went out in style though lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I've had one for 6 years with no problems so I don't why yall are having the issues you are with them.. I think they're good batteries,mine was only on 1500 watt setup at the time in my truck. I got a D3400 under hood now and D1200 in back. My YT has been in a closet resting at 12.6 volts for 7 months. Sounds like you need to charge it with a good charger and upgrade your alt them maybe add another battery in the back if needed after that. I charge my batteries with a C-tek 7002US and it'a an awesome little charger..
any issues while starting the car?
you should load test like fox_racin4 said. if you have the equipment do it yourself or go into autozone and ask them to do it for you. only real way of checking
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
New ones are not like the old ones!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
