Why did this have to happen to me? Really bummed
Awhitewookie
Really down right now guys. Just finished working on my car for 9 hours. Successfully walled it, covered in vinyl (looks awesome), wired all my batts, wired the amp and fuses, everything.
Pulled out my DD1 for the first time ever, turned the key and...
...protect mode.
I don't know where to start. Please help
1/0 Big 3
1/0 power&ground on amp
Alpine cda-9884
(4) 6x8 kicker ks68
(1) Crescendo BC5500
(4) Massive Audio stage 2 dmx 15's
(3) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Sorry I know now that sounded different than I meant. I pulled it out to use but never got to because It when straight to protect
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Ohhhh.
Remove your speaker wires and RCAs from the amp. Only the power/ground/remote should be hooked up. No bass knobs either.
Measure voltage of the positive going into the amp and the remote wire
Removed RCA's, speaker wire, and bass knob.
Turned key forward, NO PROTECT!
Voltage car off 12.8
remote 11.9
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
did you perhaps put a screw through an RCA by accedent? Ive done that once and it was hell to trace.
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
It was in protect before I connected the RCA's. Plus they run down the side of my panels and under spots that are Ford Snap Plastic so no chance but thanks for chiming in!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
sounds like you might have a pos/neg speaker wire lead touching somewhere.
edit; the littlest piece of wire touching will shoot your amp straight into protect. without making a noise or anything.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Okay so a lead touching a POS or NEG on the amp? going to reconnect now!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Now do process of elimination, plug just bass knob in, test
add RCA's, test
add one speaker, test
keep adding one by one and see how far you get. Maybe a speaker wire got pinched in a door jam and is shorting and you just don't know it yet.
EDIT: this way you don't put everything back on thinking you had stray wires at the amp and turns out you still have a problem somewhere and you have to tear it all apart again.
