I just dont use decaf. But I set with th -5. I dont think my woofers would last long on -10
Yeah... you play with fire at times.
Ive ran my set up -10 and play decaf for multiple songs straight, at a low voltage at that. (low for me)
(i have backed it down to the -7.5 track Chris made, and watch my gear)
Like you, gear choice, getting what you pay for, (and your knowledge of your gear), really show up at times. ;)
Im also about 1500 watts over what I should be giving each woofer.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It might also be useful spot set gains according to your max distortion point on the headunit at those higher levels to satisfy your 80's music...
Then leave those gain settings (a LC1 might be helpful here)
Then put on the -5db track and with those same gain settings, roll up the volume till you see distortion.
Now you have two different max volumes for your two different genre of music that are recorded at different db levels.
Snows answers are way better then mine but I believe mine might be useful sir.
I can do 2 settings. easy enough to do. I will have 3 LC-1's, high's, midbass, and subs.
I will be powering under the rms rating of my subs.
Well I mean you got n8 Kylar snd snow drifter in this thread. They are all way smarter then me but I don't see why my suggestion wouldn't work logically. And if you have LC1's connected you can easily use the dd1 to find where (-5) would be on your lc1 while turning it up... Make a little mark on it and don't turn it up past that point when your playing decaf. And so on and so forth.
Hope that helps.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Hope that helps.
Makes way to much sense. I am game to try it
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
