Mechman Alternators
12 volts at idle?
I just got a 320 amp alt for my 2.4L Oldsmobile Alero and when im at idle it sits at the 12s but when i give it any gas they go up to 14.8 every time. If anybody can help me i would appreciate any advice. I have no subs or amps hooked up, I have 0 gauge CCA from the alt to the battery, 300 amp fuse, And ground from battery to mount on alt. Got a new belt also since the pulley is smaller on this alt.
Alternator is probably tuned for slightly higher RPM.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Not charging at idle. What RPM do you idle at? Alts are typically rated at an 800rpm idle. If yours is lower, you'll see a drop in performance
Give Mechman a call.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Does your Alt have a large or small pulley. If it's large change to a smaller pulley.
"Got a new belt also since the pulley is smaller on this alt." -Copied from OP
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 499 Guests (See full list)
