Gotta rebuild wall. Need advice please
Well. Took me a long time to realize that my port area just isn't cutting it. Not even close. Need to at least double it haha crap
I am going to redo my wall and push it forward to just behind the b-pillar. As you can see from my original build, I didn't do a typical wall that involves gluing to the car etc.
This rebuild needs to be 100% removable without a trace. How do I accomplish this?
Current:
Similar to what I am planning
Things like: what method to use when connecting the sides to the bottom and top
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Youve got so much room. to truly do a wall you arent doing anything like a slid in slide out box like you have though.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Do it the same way? Build the shell as big as you can, then do trim pieces. Lay down a fuck ton of tape and use expanding foam?
I wouldn't be able to get a bigger box in that what I currently have. My port area needs to at least double so I have to do a proper wall
Correct, sir. I don't know how to ensue that it is all removable without permanently damaging anything inside the car (well I can't help what bass causes but you get the idea)
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Build it inside of the vehicle, bolt the bottom down first to an existing hole or something. Build up from that
Won't be easy to take out, but is possible.
Cover/tape everything that you don't want to get damaged
Team Flex Issues
lay down a platform, build a box like you have, "slide" it in, bolt it to the floor/frame, then make trim pieces to seal it off.
You need a flush mount that covers all the way to the outside shell and follows the contours. Look at my build log that is what I did on my last wall and will do on the rebuild.
Thankyou for some good insight. I've never fully understood how boxes are built inside cars. How do you go about attaching each side?
Already stated that isn't possible as my box is the biggest possible to "slide" in.
Will do, thanks!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
This.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
