Under hood battery recommendations
I'm looking to get a cheap agm starting battery for my 99 f150 ext cab. I wanna just get it locally.. Sears or autozone most likely. My battery up front won't hold a charge anymore so I'm in need. I have 3 d3100s, I'm not looking to get a heavy duty one with a lot of power just a battery that will do the job.
Why skimp to save $60? XS and Juice Box have awesome products that will get the job done. I'm using the juice box black cherry right now under my hood and voltage sits at 14.5 no issues and starts every time for my 03 Silverado in -10 weather
die hard platinum batteries are great batteries.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
The d65 is to much for my price range. I'm looking to spend about a $100.. I'll look into the juicebox.
I was leaning towards a diehard.. But I think it's like $220 for one that will fit under my hood...
you have a $100 limit, walmart batteries barely fall into that limit.
juicebox batts I think run 150+ and then there is shipping. maybe a duralast agm or just a regular starting bat is your only choice right now.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Check your local craigslist, search the for sale section and start by searching things like AGM, you might be able to pull up something good.
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
