*sticky* Free Tech support
What determines the power handling of a woofer.
Is it the coil spider motor?
I mean lvl 5s have 3 inch coils and so does lvl 3s.
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Lv3 coil isnt the same as a 5
Nor is the cooling
On top of the suspension handling it.
Since you worked on the eclipses i was talking about. Do you think in anyway possible you could fit a single 15 back there in optimum box around 3 cubes net (ported of course)??? Sub up port up. I mean this thing would take up the whole cargo area with the amp mounted somewhere else. Suggestion?
i have a 1990 chevy 1500 ext.cab and taken out the backseat a long time ago and currently have 3 15s but im taken that out and putting 2 18s in replacement but just have one 18 right now for temporary, but im a 15s and 18s guy and wantin to build a system with either size that'll hit at least 160db and then ill be very satisfied.
160 huh bring your check book. You aint doing it wiht 2 woofers. at least musically.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
In anyway possible do you think that i could fit a 15 inch XL in a eclipse 00-05 in optimum airspace at around 3.25 net with either sub up port up or what ever it takes????
Yes.
All up
Ray I need help I started blowing subs 2 months ago when I tested with more power. Here's my dilemna on a burp I can get the subs to jump the pole gap and make noise. The only thing that has changed is I stepped up to 14v and my barndoor is fucked.plus my amps have been gone over and don't protect at all anymore on the lows. Could it be the amps are putting out to much power during a hard clip? Could it be the box is broke? Or the barndoors are depressureizing? The 2 closest to the port will unload 1st but the farthest 2 do it too. That's how I blew all 4 a month ago all at the triple joints brand new recones with 5 spiders. What can I do to help unloading and keep my dbeez
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
