*sticky* Free Tech support
Well..
Trick question.
You need 8cuft after for 2 ported at a min.
Good luck getting that in your trunk
How do you make a removable fiber glass piece for either a section of a door panel or better yet for my A pillars?
Or how would you make you A pillars clip on still after fiber glassing??
Hey ray I heard you have done app radios, I just put in my Appradio 2 and I'm getting no sound from the speakers. Turns on , I can go to radio iPod pandora but I get no sound when it's playing. Where should I look?
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
thank you kind sir :)
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
question on where to start with box design, Ray
sub-fi sp4 15 d1
crunch gp3000 pro
max dimensions are 28 deep,34 wide, and 17 high.
do you think i can do a 4th order bandpass box with that airspace?
Okay, so I got one that might stump you:
Right now I have 2 kicker 15" comps in a ported box, 2000W Lanzar Amp(I know, I know, but will be upgrading soon) and 8G power wire. So the other day in the parking lot I was demoing them for a friend. Usually the loudest I'll ever have the HU up is like 35/60 at the MOST. It was only at 24 or 25, then out of nowhere, no bass. I go back to check, nothing's loose, the amp isn't hot at all, barely even warm. The protect light nor the power light is on on the amp, all wires still connected and sturdy, checked the inline fuse, it was fine, then tested the fuse in the amp and it was fine, but just to be sure, I replaced it (40A if it matters). Still no bass, but then after keeping the volume low for about 2 or 3 minutes, subs come back on, hitting just as hard as before they cut off, and the amp was doing fine, but after about 15 seconds of hitting, they just stopped again. Get home, still no bass, and find that the power wire was stripped to where only about 1/4 of the wire (thickness wise) was even in the terminal. So I re-strip it, put a 8G ring terminal on it, and put it in the amp. STILL no bass. Idiots up at the local shop said he'd have to blow one of the subs to see what was wrong with the system, and that's not happening. Any help is appreciated, and if it helps, no other electronics failed, so I don't think it was the battery or alty. And I do have some 0G that I'll be putting in soon, along with replacing the 12g speaker wire with 10g. I do have a spool of 4G, but idk if that'd be better, because not too far down the road I plan on upgrading to some sundowns, incriminator audios, dc's, etc.
They say money can't buy you happiness...but money buys car audio...and car audio makes me happy.
The man makes the money, the money shouldn't make the man.
1999 Chevrolet Blazer LS 4D
Pioneer AVH-2400BT (Double DIN Conversion)
(2) Skar VVX-12 D4
Crescendo BC2000D
(2) MB Quart 4.125
Image Dynamics CTX 6.5 Components
Infinity Reference 6032cf (4)
Infinity Reference 6432cf (2)
48 sq ft. Damplifier
Big 3 in 0G
Optima YellowTop D75 under the Hood
XS Power D1200 in the rear
2 Full runs 1/0
R.I.P.
1993 Cadillac Deville Touring 4D
Pioneer DEH-P7200HD Headunit
2 Kicker Comp C15's
Lanzar HTG257 2000W (For now)
2 Pioneer TS-G1344R Coaxials
2 Sound Ordnance P-35
2 Rockford Fosgate P1694 6X9's
Sounds like its a load problem and the amp is shutting down.
Like the thing is, the steup has been the same for a few months and I've played it even louder than that and nothing like this has happened. Do you mean that the amp isn't getting enough juice or too much? Cause the amp doesn't get hot at all and the light doesn't come on.
(2) Skar VVX-12 D4
Crescendo BC2000D
(2) MB Quart 4.125
Big 3 in 0G
2 Full runs 1/0
R.I.P.
2 Kicker Comp C15's
