Working on the Sexplorer, 8 Massive 15s and TONS of mids/highs, re-building everything!
This build has me inspired my friend. Keep up the great work and keep us up to speed on your progress. Very nice homie!
thanks a lot for the nice comment hommie, want updates? here they are!
Starting to seal the box :)
Ok, for this application, i felt like it was easier and better to build the trim panels around the box, screw them and carpet them instead of doing it outside like you usually see, let´s start the puzzle!
good old cardboard...
One of the side trim panels
Right side done!
Top panel done!
bottom panel done, box is closed everywhere now, it was time to start testing before adding spanding foam and some good old gorilla tape to seal everything better!!
Wind tunnel FTW!!
yes sir, now it needs to be a wind machine on the windows for a hairtrick :)
Its coming along quite nicely brother!!
thanks a lot my friend, updates in a few minutes
First test with the trim panels on, it definitely did a HUGE change, played everything way louder, and i could also play A LOT with the port, i know it will give me different results with more power, but i really wanted to get the most efficiency i could with small power, anyways,new results:
Impedance rise went from 2.4 ohms to 4.3 ohms lol, while the rise went sky high the efficiency did also, clamped 1421 watts at 40 hz and about 750 watts at 24 hz
At 24 hz
At 40 hz
It was time to finish up the "puzzle" , on this picture you clearly can see i shrinked the port area with 2 mdf woods, past that point output dropped on the meter and ears, the best i could find was 410 SQ of port and 6.25" long tuned to about 45 hz
no comments and 73 visitors? damn! haha, anyways, more updates! here, you clearly can see gaps all over the trim panels, so it was time for some good old spanding foam and gorilla tape to seal everything properly from the back...
On this picture, you can see the huge gap on the right trim panel, sealing everything first with gorilla tape then!
before...
After...
New score at 24 hz... Got lows?
New score at 40 hz, 1411 watts :)
Still some leaks , spanding foam will be my next update :)
Damn bro! Super efficient! I can't wait to see what it does with the bigger amp!
Temporary amplifier with a rat nest around it lol, don´t mind about that mess, everything is going to be cleaned up as soon as my loudforce 10K arrives and also hook up the x-over, EQ and 4 channel amplifiers.
The cadence C6 is a 6000.1 @ 1 ohm amplifier rated at 18v , in reality, it can provide you about 4K at 1 ohm and 14v wich sounds cool for testing, i´m wired at 1 ohm for the moment and here´s the first video of the explorer playing, burped a 148.1 at 52 hz and 146.5 at 29 hz, clamped 1700 watts at 2.4 ohms and 11.6v without charging the batts or testing anything, just wanted to fired it up and see how it plays, before i can test with port area, tuning, etc etc, i need to seal everything from the back so i don´t get erratic results, so far so good :)
nice air movement buddy. how many cubes is this thing? I missed it
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
Less than a db and a half over that range... damn impressive!
Gonna be nasty on real power.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Very nice work! Guess I'm gonna have to step up my game with a new windy explorer around here lol
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
  • Who's Online   0 Members, 0 Anonymous, 1324 Guests (See full list)
