Amps won't turn on, till I wiggle remote wire?
Hey guys, had similar issues a while back when switching HU's. Haven't had tunes for about 2 months but recently re-installed 2 amps to have a little bump.
With one amp everything works fine, with 2 amps neither amp turns on when I start the vehicle or turn on HU unless I pull either remote wire out of either amp and re-install it, then all is good till vehicle is off again. I have the micro by-pass chip thing for Pioneers to watch video while in Drive and also a relay kit from Auto Electric Supply behind the HU. I know when installing these 2 devices I tried one inline in front of the other each possible way because had the same issue then. The remote will only work properly when 1 amp is hooked up.
Any thoughts how can I could finally this this issue?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Anyone?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Take the bypass out amd see what happens
What are you using that relay for and what did you tap into for your source and trigger
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
With Bypass out the remote situation in question works as it should,...BUT i want to see video when I drive (fucking Pioneer).
I added the relay because I want to run multiple amps (3 currently and adding 2 more soon).
The relay (kit from auto electric supply) has it's own ground behind the HU and I ran it to it's own positive as well. I had issues with an Eclipse HU I had before the Pioneer so I chose to run new wires for everything.
I have swapped around the relay and bypass, I.E. ran one in front of the other or connected first to the HU's remote wire and it doesn't seem to make a difference what configuration i try still seems like the remote wire will only satisfy one amp properly, add a 2nd to the equation and none turn on when turning the vehicle on. Weird huh?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Have Tested the voltage on both remote wires with a dmm while plugged in to the amp?
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
wow thats weird. I hate to say it but maybe another relay is needed one for amps and one for the micro bypass. Yet another reason to dislike pioneer. Talk to Tony and explain the issue. I bet he gets it figured out. Hes a geek.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Actually I did try this and there is power there but amp doesn't turn on, truly the oddest thing. What I think is actually happening is that the bypass chip thing is not doing it's 2 cycles of positive quick when it is hooked to a relay or something because i think that's all I am doing to get it to work.
Yea, Gonna end up having to. Thanks!
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I have a bypass on an older pioneer and have no issues with remote turn on for 2 amps. My two amps are running at different voltages though. maybe try a second relay??
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
honestly that's what i was thinking about trying but don't have one laying around (shitty I know) but thanks for the idea. Still seems weird though, have to add a second relay (if it works) just to do what no relays coulda shoulda done...
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
