DC Sound Lab
Box Recommendations
Okay.. So Im buying a pair of 10" DC Level 4 m2s and will be powering them with around 3500wrms. I drive a Mitsubishi 3000GT (has a hatch). The subs and port will both be firing up.
Here's what Im thinking.. 2 - 2.25 cubes tuned between 32-33hz. Im a bit lost on port area. A friend advised me that ~35 sqin would work well, but does anyone else want to comment on the box? Im all ears..
Thanks again guys B)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
60 in2 of port + 10%
A single 8" aeroport will do well, flaring it will make it much better.
Krakin's Home Dipole Project
For 2 10s? Was that a typo?
LMFAO so true
:blush:
Was not a typo.
60 square inches + 10% is the best you can get without testing multiple boxes.
For car audio you can go on the smaller side, but do risk chuffing.
Smaller than that can risk chuffing, compression, and other unwanted disruptions.
The 'ideal" amount of port is generally higher than most people run. Anything thus far suggested will work, but krakin's suggestion is closer to the optimal. You have to find a middle ground between port area and length depending on your install limitations and hope for the best.
Edited by Souldrop
1997 Lexus ES300
HU - Pioneer MVH 7350
Processor - Helix DSP
Front Stage - JBL P660C
Mid/high amp - Alpine PDX-F4
Subs - 1 IA Death Penalty 12
Sub Amp - Cactus Sounds PF300.1
you like a lot of port krakin haha
I recommend port just the same as Krakin. There are a few port calculators that really make it easy and they also offer the formula from Small as well. I use the same program that Krakin uses and it's also the one that Bkolfo uses. All from the Loudspeaker Cookbook. Two Level 4 12" subs are right at 85" using the same formula.
And Krakin's suggestion was slightly under what the calculator suggests. It's actually 62.31"
Edited by CleanSierra
So how many of you guys have actually built a box with that much port area? I'm curious as to what the results were.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1108 Guests (See full list)
