Is bigger better?
_paralyzed_
My girlfriend keeps talking about the size of her last boyfriend and....
Whoops... wrong forum.... anyway....
My Boston Acoustics G2 15"s call for 2.0 cubic feet in a sealed box. I have the room, will a little bit bigger be any better? I would port, but these subs really weren't designed for ported use.
nice intro lol. You should ask tell her well did he have big subs noooo didn't think so. then make her sit in your car for a gruesome demo ^_^ as far as the box I'm sure you could make it a bit bigger .5 cu ft especially if you go sealed as far as if you port it then I'm not so sire
How much bigger can you make it? It takes a pretty big change in volume to have a noticeable difference with sealed enclosures.
As you make the box bigger it will lower the enclosures Qtc. A lower Qtc will start rolling off at a higher frequency but will do so at a slower rate, so you will pick up some low end output at the expense of some upper end output.
Builds:
So then, it would be ideal to create a larger sealed enclosure if, say, you have 8" midbasses picking up around the 100hz frequency range on the front stage? Also, does overpowering the sub slightly become a bigger or smaller concern if you do increase volumee? My assumption is bigger concern.
According to my girlfriend, yes
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
lols don't sound like shes over her last bf
bigger concern due to less back pressure in a bigger enclosure
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
A larger box will reduce the power handling (as Deathcards said) due to lower back pressure. Basically your subs will bottom out on less power, and the box will sound more "boomy" and less "punchy".
For people that aren't competing and/or don't have a specific reason to run bigger/smaller I would advise to stick to manufacturer recommendations. Just my $.02 though.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
So it's either 1) go by Manufacturer's recommended sealed volume (or roughly within 10% of it) or 2) just port it
You got it backwards, its the smaller boxes that sound boomy and the larger ones that sound tighter.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 5337 Guests (See full list)
