Finally tracked down a thermal issue. But what could it be?
I've been having this odd problem where no matter what have hooked up, there is this disproportionate amount of heat dumped into the coil.
If I use my mixing board as a source, I can free air one of my 12s and the coil gets stinky in about 3-5 seconds at any volume. This isn't a bunch of power either. 400 watts. There is nothing obvious happening - no strange sounds, sub is moving equally in either direction, and my multi meter isn't picking up any sort of DC offset
If I remove the mixing board and plug straight into my crossover (which then goes to the amp) I get results like what I would expect off of 400 watts. Coil stays cool enough to touch even after several minutes.
I've tried playing a square wave straight into the amp, just to see if some sort of clipping may be the culprit and I can't seem to put much heat into the coil. It remains cool to the touch.
The only conclusion I can draw is that there's something funky with the mixing board. But now I'm curious what in the world could cause this to happen?
I had a H/U that would randomly start clipping the signal to the sub, so you could replay a song and all of a sudden you begin to smell the coil from the clipping it was doing. i wound up replacing the h/u and have not had a problem since so i would at the least try another mixer to see if it is indeed that one causing the problems.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Yeah that's the piece of broken equipment... But I'm curious how it could dump that much heat into a coil without something obviously looking/sounding wrong. I mean... These subs were on a wall socket for 5 minutes and showed no signs of failure
What headunit was that?
Also... That's freakin weird mr snow.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I think everyone is forgeting snow posted in the pro audio section lol
what desk is it pro? Ill have a look at the shimetics and see if there is anything that could possibly cause it,
are the desk/crossover/amp all plugged into the same power outlet?
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
  • Who's Online   1 Member, 0 Anonymous, 1415 Guests (See full list)
