to be honest....you got another test that doesnt involve the brakes? Not wild about the idea of doin this....my brakes are slightly warped as is (they do it like clockwork every 5-6 months).
It's not like you're gonna be wearing the pads or something, its just gonna hold the car in place
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
its not supposed to slip. when i say slip, i meant you dont go anywhere when you hit the gas, or theres a hesitation with you do hit the gas.
Then what would my problem be when it shifts from second to third and it hesitates a little. like its not catching gear sorry to hijack your thread =/
To the OP checking to see if your fluid is red an not a burnt smell is a good indicator. If you are low or have a burnt smell you need to change out the fluid AND filter. If the tranny doesn't grid or slip your in good shape.
Its slipping - check your fluids
Mark
99 Eclipse Spyder
weird week. Tranny is still a little harsh but the fluid is a little above the middle of the hatched marks (where its supposed to be) and still a nice color red. I looked in both manuals I have for my car, (Chiltons and Haynes) and no mention of a tranny filter...at all. I thought that was really weird. So I went to a couple friends who are mechanics and they said its possible I dont have one. So basically Im saying f**k it and gettin one in may for 500 bucks with only 25-30k on it. Ive heard bad shit about Honda transmissions before and figured this has close to 120k on it so I mide as well change it if I want to run the car into the ground. Thanks for the help.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I'm not a mechanic in anyway but im pretty sure your car has a tranny filter. You have to remove the transmission pan to see it.
1996 Chevy blazer
Pioneer deck dehp6800mp
clarion eq
Hifonics BXI1606d (Subs)
1 18" RE MT
Box specs: 6.7cuft @35hz 14.2sqin of port per cuft (Noobtastic design)
Crunch GP1400.4 (Mids & Highs)
Boston Acoustic mids and highs
Stock alt
Stinger SP800
Bunch of 0 and 4 gauge wire
tranny will usually start slipping if its going to go out and not really shift harder. make sure you dont have chunks on your dipstick and that it is reddish (as stated above).
i dunno anything about this type of stuff, but my tranny has started to "pull"not sure if its the same as slipping, so im guessing thats bad?
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
the tranny is going out on my dads astro, sometimes it will sort of jerk the van while going up a hill or staying a constant speed. does it do anything of that sort?
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
Your car has a transmission filter, most automatics do. If you can find a transmission for $500 thats pretty good that is about the same price as a rebuild w/ a homie hookup so you'll be saving about $200-$300.
Check your fluid and look for metal shavings in the fluid it sound like your gears are grinding.
Mark
99 Eclipse Spyder
Changing trans oil is a toss up for me, ive learned over the years that if a trans is going bad and starts to get metal shavings from the gears its actually helping the gears make contact, but once you change the oil your gonna lose all those little particles and shavings and your trans is gonna slip real bad because its gonna be real smooth all around, like i said itsa toss up for me because its happened to me and then sometimes it hasnt.
