Think you know about setting gains?
oldsoundguy
does anyone know how he calculates 31.6 vrms from the exisiting factors? great video btw.
What processor do you have.
Audiocontrol overdrive but people have told me before to just take it out but for the way all my wiring is run it's not practical to just remove it
Hook a dmm to the processor and turn the gain down until it is under 6v the using the dd1 adjust the amp gain.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
OK, its official... HE is the smartest person ive ever listened to... I absolutely need a DD1. The way he talks, and describes how these things work are on a level that if i can understand it, i know YOU ALL can understand it. Thanks Tony D
I love my staffie :good:
So anti FACEBOOK it isn't even funny
  • 2 months later...
I am curious, why set the HU to max unclipped level when setting the gains, even though I don't listen to music that loud? Is it because it is a 0dB track when setting the gains and most music is around -10dB?
For example, my headunit clips at about 60 out of 62. I usually listen to music anywhere between 20-40. If I set everything to when it is at 60, won't the gains be incorrect for 30?
Everything else makes perfect sense, I am just wondering why.
Although on the other hand, the he says in the video the test signal would be 0dB I think, when do I use the -10dB track? And do I set the volume to normal listening volumes than?
And also why set the EQ to flat, even though I don't have it on flat when I play music? If the gains are set with flat EQ and then I turn some frequencies up, like 80Hz, couldn't the signal be distorting or clipping then?
0db gives you the actual max output of your source. No reason to try and get more out of your source, that is what amps are for! Setting eqs to flat eliminates any distortion introduced by the EQ. Ideally, you drop frequencies instead of raising them. That way don't introduce distortion into a signal.
If you set your gains with your volume at 30 then turn your volume up to 60 then bad things will happen. Any reason why you usually listen with your volume at 30?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
The gains won't be incorrect at lower levels. You are setting them for maximum clean signal. It's up to you to realize that you are introducing noise and distortion. And clipping into your setting by adjusting things from there. The dd-1 is about setting your gains. Just like an opcode or anything else is. If you use a scope you follow the same basic factors to do so. It's not meant as a set and forget as music and people who adjust settings vary greatly. It's meant to be your ceiling.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
At 60 volume, my speakers go crazy loud and sound like crap. I have set my sub's amp's gain using dd-1 at 60, but when i liaten to music at 30-40, the sub is really quiet even though i know for sure it and the amp can handle way more.
Do you have your speakers in head unit power
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 711 Guests (See full list)
