hdorre Posted December 27, 2013 Report Posted December 27, 2013 Im going to be using an aeroport for my next box. I can't find a reason NOT to. Edit: Im going to be using a 4" diameter port, which will be 13" long (including flares). Would 2 22.5 degree bends be THAT bad? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Afficionado Posted December 27, 2013 Report Posted December 27, 2013 You could make the outside of it look like an octoport with MDF. that would make it look pretty cool. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
alaskanzx5 Posted December 27, 2013 Report Posted December 27, 2013 Areyou using an aero port or flared pvc? either way you could get a bigger pvc pipe and side the aero put in to it as a sort of outer shell. Then use body Filler/fiber glass to make it seamless. Then paint as you want to t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
TylerParrish Posted December 27, 2013 Report Posted December 27, 2013 I always thought of adding mdf rings up until you reach the end of the flare, then you can bondo and sand it all so it doesn't look like multiple MDF rings. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
hdorre Posted December 27, 2013 Author Report Posted December 27, 2013 I always thought of adding mdf rings up until you reach the end of the flare, then you can bondo and sand it all so it doesn't look like multiple MDF rings. Thats exactly what I was thinking, but I don't have a router. The circles wouldn't look good at all lol On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
n8ball2013 Posted December 27, 2013 Report Posted December 27, 2013 They make pvc.elbows. you can find it in the plumbing section of lowes........... the plumbing section......... next to the toilets........ in the plumbing section THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
CleanSierra Posted December 27, 2013 Report Posted December 27, 2013 HunterJohnson makes MDF rings if that's the route you want to go. The angle of the bends wouldn't be a bad thing either, up to 90° bends area perfectly fine. Any more bend than that and I think efficiency could start coming into play(lack of efficiency) Im not the one you want to try to troll. Just a fyi for you.
Joe X Posted December 27, 2013 Report Posted December 27, 2013 The slower the bend turns the lesser loses you will experience so try to find a fitting that doesn't turn sharply if possible and it will work better.
hdorre Posted December 27, 2013 Author Report Posted December 27, 2013 The slower the bend turns the lesser loses you will experience so try to find a fitting that doesn't turn sharply if possible and it will work better. I was hoping you'd see this. Thank god! So two 22.5 degree bends are better than a single 45 degree bend, right? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Joe X Posted December 27, 2013 Report Posted December 27, 2013 The slower the bend turns the lesser loses you will experience so try to find a fitting that doesn't turn sharply if possible and it will work better. I was hoping you'd see this. Thank god! So two 22.5 degree bends are better than a single 45 degree bend, right? I guess that if you are willing to assemble together 4 of those you could achieve a slow 90 deg turn, yes, but it would maybe be a lot of work, there should be slower turning 90 deg turns or a dual 45 deg set, just go and see what you can find that will actually work on your space.
