The Automotive Picture Post
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Really like Roush upgrade
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
FML
25356958856_3690a54e18_b.jpgLSMotor by Kenneth Stephens, on Flickr
this is the reason i went with a junk yard ls3.. its more expensive than the other lq engines but im saving lots of money by not going crate or ls7.. i was reading on my block and it looks like i can build it into a 418.. that would put me $2000 for the crank and pistons buy a used set of ls7 heads and i will still be under at 6k around 9k installed and everything
FML
can you bore a ls3 block to 4.125?
Used to have a loud truck
FML
You can't use LS7 heads on a non LS7 or aftermarket block. Not only does it use a different bolt patterm, but the bore on an LS7 is 4.125", and it would ruin the quench area of your pistons as well increase pinging and drastically lower your compression. The L92 heads on the LS3 are KILLERS, i'd personally rather have them CNC'd than throw on oddball LS7 heads.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
