ROLEXrifleman Posted January 8, 2014 Report Posted January 8, 2014 I'm confused, did you have these reconed or just has the surrounds replaced? Rolex you sicken me. Just let me finish my pie ~ Juice
timc31610 Posted January 8, 2014 Author Report Posted January 8, 2014 Reconed, sorry about the confusion. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
timc31610 Posted January 14, 2014 Author Report Posted January 14, 2014 OK. pulled the stealthbox out and measured. There is a hump and a bracket in the way the best case scenario was around 1.3 ft3 before displacement and with only 5.75" mounting depth im extremely limited on what sub I could use. I had several boxes laying around and threw both 10w6's in a few and even overpowering them (which I only did briefly) the output was only slightly better than the stealthbox. SO, since I have a 60/40 rear folding seat I am going to build a box for a single better 12. I am thinking a Soundqubed HDS312D4 on a Power Acoustic A2400DB in a 3 cubed box. I listen to a lot of dubstep, metal and some rap. Looking for low and loud! Below is my Torres screenshot with my max dims, not sure if I need double baffle or not. If someone wouldn't mind having a peek and letting me know if I am on the right track it would be greatly appreciated! I wanted lower tuning in the 33hz range but cant seem to make it work. And the port area is bigger than SQ recommends. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
john253a Posted January 14, 2014 Report Posted January 14, 2014 Have you looked at smaller subs It a single sub For the music you lession to idd go sundown X And either a single 10 of 1.5-2k or some 8" I feel running more cone sealed won't do what you want it to So idd go ported
timc31610 Posted January 14, 2014 Author Report Posted January 14, 2014 I just noticed that screenshot cut off part of the page. I figured a decent 12 on 12-1400 rms should be a good bit louder than a single 10 on 400. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
BoomZoom808 Posted January 14, 2014 Report Posted January 14, 2014 OK. pulled the stealthbox out and measured. There is a hump and a bracket in the way the best case scenario was around 1.3 ft3 before displacement and with only 5.75" mounting depth im extremely limited on what sub I could use. I had several boxes laying around and threw both 10w6's in a few and even overpowering them (which I only did briefly) the output was only slightly better than the stealthbox. SO, since I have a 60/40 rear folding seat I am going to build a box for a single better 12. I am thinking a Soundqubed HDS312D4 on a Power Acoustic A2400DB in a 3 cubed box. I listen to a lot of dubstep, metal and some rap. Looking for low and loud! Below is my Torres screenshot with my max dims, not sure if I need double baffle or not. If someone wouldn't mind having a peek and letting me know if I am on the right track it would be greatly appreciated! I wanted lower tuning in the 33hz range but cant seem to make it work. And the port area is bigger than SQ recommends SQ/AQ subs like higher tuning they still can play low if your box is big enough with enough port area. 3.78 cu seems a little large for a single 12 as well. I would also look into another amp... I heard a power acoustic 2000 watteva amp and it sounded like maybe 300 real watts. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
timc31610 Posted January 15, 2014 Author Report Posted January 15, 2014 3.78 before sub and port displacement, little less than 2.7 net. Manufacturer recommends 2-3 ft3 so its within range. No the Precision power amp is not top of the line but it will do 1000 plus watts at 2 ohm. Thanks for the comments though. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
BoomZoom808 Posted January 15, 2014 Report Posted January 15, 2014 3.78 before sub and port displacement, little less than 2.7 net. Manufacturer recommends 2-3 ft3 so its within range. No the Precision power amp is not top of the line but it will do 1000 plus watts at 2 ohm. Thanks for the comments though. Precision power or power acoustic???? PPI gets the thumbs up Power acoustic thumbs down sorry i spaced was looking at gross volume. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Ahmed Johnson Posted January 15, 2014 Report Posted January 15, 2014 If those were your only 2 options, I would go with 2 sealed. Especially with 10's
timc31610 Posted January 15, 2014 Author Report Posted January 15, 2014 It is Power Acoustic, I was spacing last night too...lol. I know it isnt a great amp but it will be replaced as soon as funds are available. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
