Almost the death of me and my car lmao
Skax
here is what i would do.
replace your 4ga with good 1/0
use your 4ga to run power to your mids/highs amp
terminate your wires properly
if you haven't already - do Big 3 upgrade
your system will love you for it.
RF recommends a 200a fuse on the 1500.1
if you havent already - get your gains set properly (oscope/DD1)
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
^ All of this. And Fosgate's site says a 150a fuse for the 1500, and a 100a should do it for the 400.4. I don't wanna jump down your throat or anything man, but electricity is no joke and neither is anything catching fire. Take care of that electrical, you'll be glad you did.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
yeah i was plannin to do the 1/0 anyway i have 25 ft alreayd in my room waiting on me to do something with it guess nows the time since my 4awg took a shit on itself or whatever so run 1/0 from battery to cap and cap to sub amp and run 4awg from cap to mid/highs amp?
also i have a 1500bdcp what type of fuse should i hit it with and also what about the tma 440.4
havent done the big 3 upgrade and idk how im really new to the car audio and im trying to learn the best i can :/
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Bad connection. See where it melted? Where the terminal touches the wire.
Those crimps don't cut it for the amount of current we pull in car audio
ok could you send me a link of the 2 fuses i needed to order? and also i have a circuit breaker under my hood atm since i couldnt find anything else locally around me but 100a glass fusses and it would just bust them as soon as i put it in so i have a 200a anl i guess ill replace under the hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
any idea what kind of crimp i should order i had all of it installed sounds like they did a shitty job :/ ill do my best to replace what i can by reading got a link of a crimp for some 1/0 awg i can order?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
HOT solder or hydraulic crimp any ring terminals.
^^^THIS^^^
Find a torch, rosin flux, learn to solder. Or invest in a crimper and some copper crimp lugs, choice is yours.
You can also solder the closed ended crimp lugs, but you can't do it the other way around and crimp solder lugs
This is a crimp lug. Either crimping or soldering is acceptable
This is a solder terminal. You can only solder it. Long story short, dissimilar metals don't fuse very well
so i guess what im looking at now is fusing all the connections and also i have the 200a fuse for under the hood i guess i should replace with that circuit breaker and run some 0awg on the 200a fuse and also what im needing to get is
150a fuse from cap to 1500bdcp
100a fuse from cap to tma 440.4
some cramps for 0awg? and also the 4awg if i need to replace them??
if anyone could link me these 3 things i need id highly appreciate it :/
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
These should do the trick, holders with fuse included. Just oreder one with a 150a and one with a 100a.
http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
Lane AKA HeroKight
R.I.P. Molliboo
You hear that????
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
