Kyblack76 Posted January 30, 2014 Report Posted January 30, 2014 I used a RF 3sixty.2 in my acura, using the oem head unit. I used the "sum" feature to gain me the high highs, and the lower lows. When i "tapped" into the rear 6x9 signal with a LOC, i couldnt run below 37hz. Was annoying. It was the OEM audio doing "its job" id expect. I installed a .2, and summed 2 channels. It worked OK, but, I really felt like i was still "lacking" something. Its hard to explain. I almost got my hands on a RTA, to run some pink noise, and really see if i was getting the responce i was wanting, but, i said fuck it and chose a different plat form.... Thats all i got bro. I hate OEM intergration. Id almost rather just blue tooth a ipad to a DSP or some other shit... good luck. (can you show me what line 7 and 8 are, coming INTO the factory amplifer??? is that a audio sig?) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
KenC210 Posted January 30, 2014 Author Report Posted January 30, 2014 Line 7 and 8 coming into the factory amplifier come from the radio. I could tap into those wires before the amp from the radio but i will not have any fade. Plus i believe the amp controls most of the volume levels and frequencies. Not positive though. So when you say you summed the 2 channels how exactly did you do that? Yes i am starting to hate this JBL system also. It is becoming a real pain to upgrade. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
KenC210 Posted January 31, 2014 Author Report Posted January 31, 2014 So i am just going to buy an Audiocontrol processor to play around with. If I happen to mess things up i guess its a lesson learned. I would just like to know so differences between the DQ-61 and the LC7i? Or is it just the EQ and signal delay? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
White Lightning Posted January 31, 2014 Report Posted January 31, 2014 I really hope if you do this, you have plans to get rid of everything stock in that truck except the source unit ... That's what the processor I listed is made for ... You may have to re-wire everything from the processor back ... just as if you was constructing a bran new setup in a vehicle that's never had a system in it before ... Once you get everything from the headunit to the processor ... Everything else should fall into play as if you was designing a system from the Audio Control's diagram ... meaning aftermarket wiring / amplifiers / drivers / subs / ect ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
KenC210 Posted January 31, 2014 Author Report Posted January 31, 2014 Oh yes i plan on everything brand new except the rear speakers and head unit. There is a lot of reason I would like to keep the factory head unit. I want to keep steering wheel controls, XM satellite, back up camera, basically all the features that run from the factory unit. If i buy a new head unit i would have to a lot more work finding the wires and wiring everything else up. I wanna try and keep it the simplest as possible. I have done a lot of looking into this. Although I am not to sure yet on the rear speakers. If i want to keep the rear speakers I would choose the DQ-61, LC7i, or the LCQ-1. However if I want to replace the rear speakers also i would almost be choosing the LC8i, But I would like the EQ features as i would like to run a good 3-way setup in the front since i have the factory locations. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
775Tundra Posted January 31, 2014 Report Posted January 31, 2014 So i am just going to buy an Audiocontrol processor to play around with. If I happen to mess things up i guess its a lesson learned. I would just like to know so differences between the DQ-61 and the LC7i? Or is it just the EQ and signal delay? Yes the eq and signal delay. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
KenC210 Posted January 31, 2014 Author Report Posted January 31, 2014 I am going to go with the DQ-61. Just another quick question the factory sub is a mono sub. Would i be able to put the pos on the right and the neg on the left to create a left and right output or should i just leave it in either left or the right? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
newls1 Posted January 31, 2014 Report Posted January 31, 2014 Just a simple question to the OP... why not CALL audiocontrol and explain your question to them as im SURE they can steer you in the direction you need to go in. That is what their in business for..... people like us! Here is their numbers..... http://www.audiocontrol.com/c296/Contact-Us.html I love my staffie So anti FACEBOOK it isn't even funny
KenC210 Posted February 1, 2014 Author Report Posted February 1, 2014 Yes thank you i got it figured out already. I just needed to do a bit more research. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
newls1 Posted February 1, 2014 Report Posted February 1, 2014 Yes thank you i got it figured out already. I just needed to do a bit more research. good deal man, hope all works out for ya I love my staffie So anti FACEBOOK it isn't even funny
