Joe X Posted January 28, 2014 Report Posted January 28, 2014 You would need around 60+ square inches of port area for a slot, likely will need to turn at the bottom.
KiKaZz74 Posted January 29, 2014 Author Report Posted January 29, 2014 Rhats fine. Could u do slot port dims? And where at on the box? Like full width or towards one side or another? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
Joe X Posted January 29, 2014 Report Posted January 29, 2014 I don't like the following too much but just for you to see: L Port Internal Assembly Parts:Top to Bottom: 19 1/2" x 21 1/2"Port Left Side Assembly:19 1/2" x 3"3 3/4" x 3"Port Right Side Assembly:19 1/2" x 3"3 3/4" x 3" The spec ends up being 4.1 cubes net @35Hz
alaskanzx5 Posted January 29, 2014 Report Posted January 29, 2014 a slot port on the top going from one side to the other (full width of the box) would be narrow to avoid to much port area and that can create issues with port noise. making it the full width and wider might not be possible due to the needed length to get the tuning down to where you want it. the length might be to much and not exactly possible to achieve. like the port turning up towards the sub along the baffle would be a bad idea. I would stick with aero ports. easy to install and less port displacement. also makes it quick and easy to change out ports for a different tuning freq. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
KiKaZz74 Posted January 29, 2014 Author Report Posted January 29, 2014 Thank you very much joe. Damn. Im thinking aero now that ive seen that. Cuz sub will be offset to the right due to seating. I want it directly behind my seat to avoid jackasses running something into it from center console. And to avoid that rubbing on it. I planned on putting amps on that far side but if a port is there idk. Maybe one on top and the other on side or the front opposite of the sub? Or could I do port on top and bend it if I had a 90° joint? Might be getting to deep in this or overthinking it. Im just kinda confused is all And thats what I figured withe the full width port. Couldnt get close in torres at all so I figgured it wasnt gonna work. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
alaskanzx5 Posted January 29, 2014 Report Posted January 29, 2014 port to driver side has proven good on setups like this. maybe put the sub amp on the front to where you can see it between the seats? then the mid/high amp on top. would make them viewable to show them off. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
KiKaZz74 Posted January 29, 2014 Author Report Posted January 29, 2014 What u mean to driver side? On top or side? Im just getting lost. Thanks for bearing with me guys. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
Jhunt94 Posted January 29, 2014 Report Posted January 29, 2014 What u mean to driver side? On top or side? Im just getting lost. Thanks for bearing with me guys. I'm pretty sure he means the port on the side, fired towards the driver's side. I had a box similar to that with a 4" aero port on the top and I liked the way it sounded. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
RooTxBeeR Posted January 29, 2014 Report Posted January 29, 2014 I would say get a CT 1400. These subs are rated at 1250 of I'm not mistaken, and knowing sundown I'm sure these can take more than that. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
alaskanzx5 Posted January 29, 2014 Report Posted January 29, 2014 yep, I mean port to the side facing the driver side. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
