boom50cal Posted February 18, 2014 Report Posted February 18, 2014 Looks like you have a retarded half functioning cop car in your truck, especially if it's up high lol. I mean half retarded as only one color is there On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Rudemaxxx Posted February 27, 2014 Report Posted February 27, 2014 make sure you place this gauge in a EASY to REMOVE location for easy access to replace it. Do not forget to set the gauge with a real volt meter as well, as it does not come even close to accurate out of the box (or atleast the 64 i went thru didnt) I thought your name was Don Draper... I've been watching too much Mad Men xD. But ^^ is important, with the stingers you get to calibrate them which is nice. Welcome to my sig My build on my 2008 Jeep Grand Cherokee Laredo 4x4: 2 Sundown SA 12's Sundown SAZ 1500d v3 Alpine CDE-HD148BT Hertz 165 Speakers Atrend Carbon Enclosure Stinger SPP925 Battery Sky High 2/0 & 1/0 Power Wire & Big 3 Legal 145.2 dB. Team Sundown.
Skax Posted February 28, 2014 Author Report Posted February 28, 2014 so run it with some 14ga speaker wire? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Sky Posted March 1, 2014 Report Posted March 1, 2014 Your going to run your volt meter off of 14g? 99 F-150 Build Log
bbeljefe Posted March 1, 2014 Report Posted March 1, 2014 If your intent is to monitor the voltage at your subwoofer amp you need to have the power input for the meter wired directly from the subwoofer amp's terminal. If you only care about general system voltage then you can get the signal from the head unit. I'd really like to know: Does it make a difference if the positive is on the amp but it's grounded at the headunit?.....Does the + and - need to be on the amp or just the + ? To get the most accurate reading possible at the amp with a DMM, you would probe the positive and negative amp terminals. You should do the same with a permanently installed voltmeter. And I would run a wire that's a bit larger than necessary in order to eliminate the possibility of voltage drop in my test wire. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
Skax Posted March 12, 2014 Author Report Posted March 12, 2014 how do you go about probing the positive and negative terminals and what size speaker wire would you recommend? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
boom50cal Posted March 12, 2014 Report Posted March 12, 2014 16 ga speaker wire would work just fine and dandy. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
JEFFYBOI Posted March 12, 2014 Report Posted March 12, 2014 I just bought the Stinger SVMB Blue voltage display so I will be doing the same thing. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS
JEFFYBOI Posted March 12, 2014 Report Posted March 12, 2014 Im questioning this.... I would think the headunit and amp will see different voltages... I would think you want to monitor your voltage on your amp. So that being said don't you want to wire it to the voltage your amp is seeing? "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS
