Ok. I got a hdc3 18.
Kojis_26
The saying is," if there is a will, there is a way".
Good luck, I'm down to see pictures of the building process. I hope you end up able to fit it in the trunk, and I hope you can hear Bass over all the rattle you'll generate :)
Post pictures when you get started
If there's a way there's a will. In. Havin it. Done.
Post your max dimensions for a box, in some cases it can be done right.
You could do a sloped face on the box if it wouldnt fit vertically. I mean with a more elaborate design you could make anything fit. it might not be ideal tho.
what car again?
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
fiberglass the whole trunk into a enclosure
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
We know you have a 94 Accord Ex. That doesn't tell us how much room you have. You'll need to take a take measure and snap some measurements. You also have to keep in mind of the dimensions you gone us can fit THROUGH the trunk opening. If not, you'll have to build in the trunk.
I have fired a 18" sub up in the trunk, also a pair of SQ 2.5 15s up in the trunk. Both setups slammed and sounded good INSIDE. But out side was a vary bad rattle. Super bad! Only down side that I had was they sounded good with windows down. If windows were up it didn't hit as hard at all. You can do it but your better off with some 12s. And not all the bs that goes with doing this kinda build.
C546C811-6750-4B9B-A6D2-CA712AF99333_zps
5CCF553A-2C67-464E-9BEC-00C07045C202_zps
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3199 Guests (See full list)
