hdorre Posted February 25, 2014 Report Posted February 25, 2014 You DO NOT want to stack terminals on the alternator. Stacking ring terminals on the alternator WILL cause the regulator to overheat.. The regulator will overheat and possibly burn up the regulator. If you need multiple runs run them from the battery.. NOT OFF OF THE ALTERNATOR The regulator will overheat and cause the alternator to be less efficient We understand that the regulator will overheat, but what is the reasoning behind that. Essentially what Im asking, is WHY will the regulator overheat? Im curious because like many others here with high output alternators, we add on 1/0awg (most of the time) and keep our stock charging lines on the alternator. Before I go and terminate my stock wiring, Id just like an explanation of why our current setups are harmful for the voltage regulator. Im not trying to start problems, Im genuinely curious. Thank you On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
leonfowler Posted February 25, 2014 Report Posted February 25, 2014 ok it will over heat but how would another ring terminal cause it to heat up..I have 2 runs from my alt to my battery ..how does the alt REALLY know there are 2 ring terminals or runs on the post? 2004 Chevy Trailblazer LT Walled- 10.5 cubes net tuned 33Hz 2-15 inch AA Team subs D2 Americanbass- 750.1 1 yellowtop under the hood , 4 c&d 88ah batteries in rear mechman-270 pioneer headunit-4200UB 4 soundqubed supertweeters phoenix gold 2 channel back up camera stinger volt meter 22 years old and still have alot to learn..lets get it
Jessica Posted February 25, 2014 Report Posted February 25, 2014 Lol I'm in. why!? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Omega5002 Posted February 25, 2014 Report Posted February 25, 2014 Posts statementDoesn't explain Sounds like an excuse to void warranty 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Noel989 Posted February 25, 2014 Report Posted February 25, 2014 Posts statement Doesn't explain Sounds like snafu Lol Build Log - http://www.stevemead...-cruiser-el-pt/
Omega5002 Posted February 25, 2014 Report Posted February 25, 2014 Posts statement Doesn't explain Sounds like snafu Lol At least he eventually explains lol 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Noel989 Posted February 25, 2014 Report Posted February 25, 2014 Posts statement Doesn't explain Sounds like snafu Lol At least he eventually explains lol Let's give mechman hmm 5 months lol Build Log - http://www.stevemead...-cruiser-el-pt/
Agreene Posted February 25, 2014 Report Posted February 25, 2014 here is the actually answer, in 16 inches or 26.340 cm of OFC 1/0 wiring your resistance is 1.723 x 10 ^ -6 per centimeter. so small you that its barley there. we will assume that is 0 16 inches = 26.340 centimeters / your resistance is 26.34 CM/ohms to calculate amperage ( I = V * R ) ( I = current or amps) assuming charging is 14.4 volts I = 14.4v * 26.34ohms 379.296 amps allowed also don't forget heat is energy which would raise the resistance allowing more current to travel through assuming you are referring to ofc wire yes you are fine
MECHMAN Posted February 25, 2014 Report Posted February 25, 2014 For instance If you have a weak battery up front lets say 12.2 or so and your load of batteries in the rear are in good shape resting at lets say 12.8 or so .Then you have your battery bank backfeeding to the front now you have the current from your battery bank at XXX amount of AH coming back to the alternator trying to balance out the rest of the system plus the output of the alternator right at the output stud then the output stud can get hot and potentially melt off.. Not to mention the added weight of the cable on that 8mm stud which is pressed in could become loose and cause resistance causing none other than FAILURE 1-888-MECHMAN www.Mechman.com [email protected]
AA98hoe Posted February 25, 2014 Report Posted February 25, 2014 I have four per alt never had a issue .. An I have them stacked in back battery bus bars were amps are drawing 1000 amps each.. 1-1/0 will not support 370 amps very effiently especially as the run gets longer that would be more resistance trying to push 370 amps through that wire than multiple lugs TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
