doubling up MDF?
ncc74656
i know that 3/4" is to flexible for my subs as ive tried that in the past. if i use 2 sheets of 3/4" i wont have enough internal volume for my application/size. is there any issue with using a 1/4" sheet glued and screwed to a 3/4" sheet? or maybe 2 1/2" sheets?
nothing, gutted
Do 2 sheets of 1/2 glued and screwed. and brace it good with dowels or threaded rod
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
204.25 in2 of port area, .38 bracing, 30hz tune, 14.37 cubic net volume. is my math correct first of all and second what do we think of the design?
this is what i have mocked up so far, its the second design: MFLyfWx.jpg
nothing, gutted
screws are useless after glue dries might as well just spread the glue like butter on bread make sure there is good coverage and glue them and put weights on the sheets untill it sets... save a few bucks on screws
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Only if the right glue is used.
Adding a piece of 3/4 to the underside of the baffle will take away such a small amount of internal volume that it won't really effect the box. You are better off losing that negligible amount of airspace and having a good strong baffle than having a floppy baffle and perfect airspace. Double 3/4 that baffle!
your saying i should add another 3/4 to the baffle in the design? the baffle is currently 1.5" thick with the rest of the port being .75" and the box itself being 1". so a 2.25" thick baffle is what your recommending?
if i had the space id run the entire box as 1.5" but i think the best i can do is to add some wood braces here and there.
nothing, gutted
Glue is the true bond when working with wood. If you're not using the correct glue, even screws won't save you from a badly built enclosure.
You can't spare an inch and a half on the sides and top and botto.and three quarters of an inch on the back and put an extra baffle on the outside?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 3301 Guests (See full list)
