ok guys got 2 12" sundown sa12 and honestly very dissapointed
had it on a orion 1200D and honestly my 2 12" t3 audio t600 subs played alot louder
im not a big big fan of lows however looking for a sub that would excel from 35hz + playing note in the 40hz extremely well
so hence i want to able to get lows however i want it to be loudd
my mids is not car audio mids. i use pro audio mids consisting of 2 10" RCF midbass with 2 1" compression drivers which are in external boxes to play outside the car
so what is the best sub sundown have to offer me that would be able to play high notes very well and yet i can get lows ?
So in the title you want to play louder than lower, yet two references in your post state you still want to be able to play low. As far as comparing the SA-12's to the T3 audio 12's, did you just simply, switch the subs out in the same box? If so that is probably the reason why. Different subs like different enclosures. ANd to be honest, that is key to getting what you want. A properly designed box will give you the results you want.
  • Like (+1 Rep) 6
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Yeah man, The SA's need a pretty fucking big box, especially for a tier 2 sub. The SA's also get a lot louder once they get broken in vs. out of the box but that's pretty much every sub. Mine shake the shit outta my car hitting like 33hz bro so they have no problem hitting lows. If you still think they're garbage then go up to the X series or the Zv3's or Zv4's. They're all great but you're gonna have to get a new box for sure because they're big as hell. like the reply said, you should get a bigger box for sure, I know I had to when I was upgrading from my Memphis PR-12's. I literally broke the box they were in before because the Sundown's didn't have enough room.
Welcome to my sig :D
My build on my 2008 Jeep Grand Cherokee Laredo 4x4:
2 Sundown SA 12's
Sundown SAZ 1500d v3
Alpine CDE-HD148BT
Hertz 165 Speakers
Atrend Carbon Enclosure
Stinger SPP925 Battery
Sky High 2/0 & 1/0 Power Wire & Big 3
:domodance::domodance: Legal 145.2 dB. :morepower1: Team Sundown. :domodance::domodance:
cd64929e-8a60-41ea-b784-c5c6096f49b8_zps
Off my build (look at my sig) I hit a legal 145.2 dB out of a trunk lol. They get loud, I promise.
2 Sundown SA 12's
Alpine CDE-HD148BT
Hertz 165 Speakers
There's your problem.
Your problem is in your enclosure , go remove the subs and search for it in the box. Report results.
I'm just kidding, kinda. Your problem IS with your enclosure probably. You need one designed for your needs I believe. That's where the biggest gain likely to be noticed by you and give you what you're looking for.
Shit I didn't even think about that. If you don't have extra power sources i.e. extra batteries, big 3, etc. then you're gonna basically be to do something like running a Darrari on a scooter engine lol. Electrical upgrades make almost all the difference in the world and are absolutely necessary. Almost as necessary as a bigger box etc.
2 Sundown SA 12's
Alpine CDE-HD148BT
Hertz 165 Speakers
Get a proper box
I had no problems getting the pair of my buddies old SA-12s doing being rather loud from the trunk of my Cadillac in a 4th order bandpass ported thru the rear deck.
Of coarse I was raping them with a Sundown SAZ-4500.....
But they get loud regardless if you know what your doing with them.
Stock alt, 2 batteries voltage drop to only 12.2ish at idle with a 5,000 watt amp.. and doing it with CCA wire!
Edited by Audiofanaticz
  • Who's Online   0 Members, 0 Anonymous, 1090 Guests (See full list)
