Voltage- How low is too low?
shit I wired my 3.5k at .5 on bone stock electrical and played it like that for a little. My hifonics highs amp protected from low voltage before my dc ever did.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
All manufacturers will include a specified input voltage range in their user manuals.
Review the manuals of all your equipment.
Note the highest MINIMUM value of all the equipment and don't go below that while using an analog voltage meter.
If you use a digital display voltage meter then its most likely an averaged value and therefore you'll want to increase your allowable lowest voltage since the averaged reading will miss some peak drops.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Snow posted a topic like this a while ago and got nothing but "low voltz is bad and smoke amps" or "it causes clipping yo,"
Until someone proves that staying on the low side of the amplifiers working voltage is harmful to the amp, I won't be scared of dipping into 11s. Even high tens.
There is a low voltage protection on amps for a reason. If 11s or 10s hurt the amps you would think most manufacturers would raise the protection voltage higher than 8 or 9 colts.
Again, if someone can disprove this with factual evidence, im all ears:)
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
A manufacturer will give a specified range to operate their device in.
As long as you stay in that range, then the product should work as advertised for its specific design life.
Keep in mind, as I mentioned above, some voltage meters may not pick up peak drops so the amp could be subjected to lower voltages then the user realizes.
Most modern amplifiers will have regulated power supplies which means that if the voltage drops, the input current will rise to allow the amplifier's power supply to stay constant.
With increased current comes increased heat (P=I^2*R). Heat loss would increase with the square of the current.
Increased heat inside of an amplifier will take an effect on the aging of its internal components, specifically the electrolytic capacitors.
Therefore in general, its best to keep the amp as cool as possible.
Of course, if an amplifier is rated down to 10V, it wont blow if you run it at 9.9V. The manufacturer will have some design margin in the product for reliability.
But the further you push the limits, the faster the device will wear out and fail.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
if the car doesn't stall, you have enough voltage.
lol.
pwn! ... thx |
V
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
Wick's you're the best..
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
Till that ish goes into protect..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 4316 Guests (See full list)
