New car, new build, not new to the forum, ive had a build log from my 00 durango on here for a while now but it was time to get a new car. I got myself an 06 Subaru Outback XT Limited completely stock... for now... I plan on keeping it a clean install all around, from the audio to performance upgrades.
37984EED-0377-4F74-8FC3-0DFAB836341F_zps
start of the audio collection thats going in the subie.
Skar zvx18 and Skar sk1500.1
F9FE5740-EC1E-497F-AF65-1BA9F9B8981D_zps
5C9C98BB-6EE1-44AC-8F05-DAA9E7CA0181_zps
3402F852-D991-4971-BA40-AEB53766C9AA_zps
Cant do anything with the factory radio since the climate controls are integrated... so i got this! Rockford 360.2 with a palm to bluetooth to it and control everything!
5D31E8C5-2E3F-43DB-9556-4BB8ECFB6A66_zps
started the amp rack today while everything else is waiting to get ordered or be delivered.
3BB68AC1-6F0F-4387-89B4-CD0071005EDF_zps
A8FA4BBB-432C-4FA3-BA69-80F2FE3E00B0_zps
199A18B2-A4C1-4947-AFB1-A16F67F593D4_zps
360.2 and XS D375 will be going under the amps.
90DDE78E-0853-4161-BDEC-B10F950F6948_zps
amps will go on top with the plexiglass between them showing the 360.2 and XS battery. and all of this will be under the floor where there will be another plexiglass window showing the amps.
7B9349A3-6096-4415-A180-C6AA5A45FDEA_zps
ADA59DE5-FA9B-41F7-A3A5-E6148DF9816B_zps
4ED4C67F-2FB9-4478-8C1C-771ED29C76D9_zps
01ce3298-41c7-4d47-b1fe-ad4188e37018_zps
1D9BF093-352E-42E8-8621-929E90C0FC78_zps
not too crazy about how the plexi just ends... maybe ill add a little wood to fix that so it matches the corners on the other end but that was it for today, im designing as i go so its a slow process.
already changed some plans... instead of having two amps and using crossovers for the speakers im going full active since i have the 360.2... so that means i had to redesign the amp rack a little... so here it is.
E7C98C96-227E-4349-8D9F-2BDB16FC105D_zps
1FFAA6B2-106F-43B9-8ACB-D7EF70196FBF_zps
DA494116-464C-40A0-9757-076E2DFC52B4_zps
amps will be over lapped and almost touch front to back and is about 1/8" from hitting the top... took a while to figure everything out but since the other two amps are the same size it made it a little easier. the hole in the bottom will now be used for fans.
7F02CF7C-5D40-4DF6-BEC9-E38B2D461C63_zps
9ACDACCD-9E08-4722-B9ED-C70C2CF861A9_zps
also buffed hand polished and waxed my car today... it really needs a full paint job though since its so scratched up and has miss matched paint, but it helped a lot!
C1F49545-CB0D-41FF-89EB-D318FF34B3D7_zps
I see good things coming...
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
For your amps you can mount them on plexi trimmed to the exact dimensions and then edge light it to give it a little pop
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
thats what im looking for!! i was trying to come up with an idea so they werent just sitting there.... hmmm
Yep cut it out to the exact dimensions then cut out the same shape on the inside. Silicone some leds to it and light it. It'll look like it floats on the light. Just gotta be careful you don't cracked it when you are m I uniting the amps or the plexi frame. You can choose to frost the edges or you can torch em to clear it. It's up to you
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
sorry for lack of updates, I got laid off recently and my new job is only part time until I find something else... but ive been trying to keep busy and doing what I can on my car without spending money.
Time to run some wire!!!
7082BE30-CA8A-491D-99C1-9C922847267F_zps
357B1738-038C-434B-8B08-2F497EF5DB01_zps
BE504584-5EC6-45E2-9059-11CA0CC3A8C7_zps
9221F372-6795-4511-AFAD-4E4B3249BD05_zps
as soon as i got this far i got a call from my wife needing a ride while her car is getting the windshield replaced...
3D2F1227-81C4-44E2-98C2-98923671C17A_zps
8DEBE9AF-6D83-4C4B-B81A-71D138BE0653_zps
this area looks good to run wire through... just gonna cut the vent... "FOR THE GOOD OF THE INSTALL!!"
AB7BCDAB-4E07-48CE-99BB-F18DABA85949_zps
added some spare wire looming from my last car to protect the wire.
7D497C5D-AA63-456F-85FA-DFD3FCD41268_zps
FB63D3A8-8CD4-4ED4-9567-89ADF0D636A4_zps
tore up some foam padding on the underside of the carpet so it still lays evenly.
E69A4C21-67DC-45FE-9A6C-16100ABF3524_zps
4D33C820-9E57-40D0-996E-CFFC39EC0836_zps
had to cut this foam too... "FOR THE GOOD OF THE INSTALL!!"
D4BC3AC4-1EAE-4381-A9B0-BE59CF96DD18_zps
000B2F3F-85F2-4C5E-868D-F134605690E5_zps
77DF43AF-DB25-4348-B73D-60F00FE6EF6A_zps
30B1A475-BD47-4164-B219-ED441EF996D1_zps
also found a dash kit for my car, its JDM and i can only get it from japan but i ended up trading a friend my rockford 360.2 for a new pioneer 80PRS!! pretty excited for that!
Picked up some plastidip to change up my car, If you know me you know i cant have what everyone else has... It has to be different! haha
0578059A-F454-4497-86F9-D86D2AD2DB8A_zps
6615B27C-6F9F-447E-B582-7B849A70C1F0_zpsAF63ACD6-96A0-4C49-8EEE-B2DF3886CBC2_zps
62512C03-3EB2-4FC4-86F9-9A61352329AC_zps
F74DFBDE-5E33-487F-95E3-9DEF4E437FB2_zps
EAD278C9-4904-40A9-8C9C-A67624E790AE_zps
BED6F0DF-0197-47F0-A8D2-C878A5FC7D70_zps85918B14-146B-4ADD-A732-8044681AD46C_zps
851C5A63-E433-474B-B385-C6A326841BE9_zps
658270AE-8818-4F32-A705-78DEBDA38E28_zps
I have a sweet idea for the emblem, that's why its not on yet. And I plan on making the headlights white and black. If you havent noticed im doing a black and white theme, there will be color in it too just haven't decided what color...
